too much fuel going in to engine!!!!
Old Apr 22, 2004 | 07:37 PM
axle_muzkeys's Avatar
Default too much fuel going in to engine!!!!
i have a 88 crx hf i swaped a d16y7 block with a d16y8 head. im using a crx si intake manifold along with distrbutor. everything is set correctly. too much gas is being injected to the engine causing it to flood. dont know how to correct this problem i have a hf ecu with a set of hf injectors and a si ecu with a set of injectors.
Old Apr 22, 2004 | 08:26 PM
jdmoutlaw's Avatar
Default Re: too much fuel going in to engine!!!! (axle_muzkeys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axle_muzkeys &raquo;</TD></TR><TR><TD CLASS="quote">i have a 88 crx hf i swaped a d16y7 block with a d16y8 head. im using a crx si intake manifold along with distrbutor. everything is set correctly. too much gas is being injected to the engine causing it to flood. dont know how to correct this problem i have a hf ecu with a set of hf injectors and a si ecu with a set of injectors. </TD></TR></TABLE>
The only time i have had this problem is with a bad ecu.
Old Apr 24, 2004 | 10:06 PM
Default Re: too much fuel going in to engine!!!! (jdmoutlaw)
thanks for the help it solved my problem.
1990-hf
15
Feb 19, 2005 08:38 PM
Tyson
Aug 10, 2004 12:50 PM
Sampsonite987
Mar 30, 2004 02:11 PM
91crxmachine_2
24
Oct 11, 2003 03:48 PM
allmotorEG-SI
Mar 31, 2002 12:34 PM
