P28 ECU for a JDM H22A...
Old Apr 22, 2004 | 06:49 PM
H23AHybridEG's Avatar
Default P28 ECU for a JDM H22A...
Hello!
I'm swapping a JDM H22A into a 1992 Civic CX. I'm looking to purchase a P28 ECU for this swap, but the only P28 ECU's for the JDM H22A that I can are chipped with some sort of program. Where can I find a P28 ECU with the stock redline and VTEC engagement of a normal JDM H22A that I can run with my swap?
THANKS!
Old Apr 22, 2004 | 08:04 PM
C M S's Avatar
Default Re: P28 ECU for a JDM H22A... (CivicH23AHybrid)
http://www.ebaymotors.com
Old Apr 22, 2004 | 11:16 PM
Ransom's Avatar
dont buy the ebay chips...www.jdmshit.com has a h22 program for the p28.
Old Apr 23, 2004 | 04:26 AM
Default Re: P28 ECU for a JDM H22A... (LudeSH)
I know that http://www.jdmshit has a P28 with programmed with a 4800 VTEC engagement and 8500 redline, but I'm looking for an ECU that doesn't have such a high redline. I don't feel comfortable running a 8500 redline since my engine is all stock...
Old Apr 23, 2004 | 10:01 AM
redStorm's Avatar
I got a P28 with a customize 1.8 liters Skunk2 program that was ajusted for the h22 2.2 liter displacement.
Spec :
VTEC 5000
rev-limiter : 8000
I got it off http://www.ecutuning.com
Old Apr 23, 2004 | 10:06 AM
heartmyEG6's Avatar
who cares if it has a high red line
just dont go there then
Old Apr 23, 2004 | 11:54 AM
Ransom's Avatar
Default Re: P28 ECU for a JDM H22A... (swinus)
Im not sure but maybe they can modify the crossover and redline for you and still have the h22 maps...
Old Apr 23, 2004 | 07:01 PM
UpstateCivic's Avatar
Don't worry about the rev limiter. You don't really want to run a stock p28 anyhow. I ran one for just a couple of days, and it's better off chipped. I have a stock block, just bolt ons and I never run it past 7500. Just let off the gas. Just get a stock p28 or a p28 with the JDMshit program. You'll be happier.
Old Apr 24, 2004 | 09:23 AM
iH8RICERZ's Avatar
Default Re: P28 ECU for a JDM H22A... (UpstateCivic)
I could help you out, and put the vtec x over and rev limit to where ever you like...pm me for more info
thanks
Jason
Old Apr 24, 2004 | 10:24 AM
Ddogz15's Avatar
Default Re: P28 ECU for a JDM H22A... (iH8RICERZ)
8500 redline doesnt mean shift at 8500 all day, lol....run it to the normal 5 grand, chipped ecu's are alot better for performance then stock...buy them off honda-tech tho, dont go ebay......jdmshit, ive heard has good feedback ....GOODLUCK...
Old Apr 24, 2004 | 01:24 PM
Thanks for the reply!
I guess I know where I'm getting my ECU from now...
Old Apr 24, 2004 | 02:17 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
we run the jun program for the h22 on a p28 we can "chip" your p28 feel free to call 909-373RACE
Old Apr 25, 2004 | 11:56 AM
Newman's Avatar
New User
The H22A program that we run (JDMsh!t H22A program) is a stock Prelude Type S map that is modified to run with specific settings to the fuel & timing curves. We're basically running the same setup in our track car with a Hondata S200 and we took those same maps and put it onto a stand-alone program to make it work well in the H22A. On the butt-dyno, you can't feel a difference but when I have time I'll take the car to the dyno and throw different ECUs into the car. FYI, those who have a "Mugen/Skunk/Vision/JUN/RPT/etc" chip, most of those are programs for B-series motors and when you put a B-series map onto a H-series motor, it doesn't run well at all.... no low end at all.
8300 isn't high for a redline... we could lower it but I know of some people who are running some Type S cams, high comp pistons in their H22, and putting down over 240 whp at 7800-8000 rpms. On a stock JDM H22A, max HP is at around 7200-7400 rpms. If the rev-limit was at 9000, then I could see a potential problem but low 8000's isnt high.
borrego_cd5
Apr 27, 2011 10:00 PM
turbosol18
Nov 3, 2007 05:38 AM
732xghost
Jul 26, 2007 03:03 PM
Preludes'R'Us
Oct 30, 2005 07:23 PM
O RLY
Oct 5, 2004 10:42 PM
