Does anyone know how to remove climate controls from ITR?
Old Apr 22, 2004 | 05:10 PM
ITRITR
Guest
Posts: n/a
Default Does anyone know how to remove climate controls from ITR?
I need to know if there's bolts that hold the Climate Control unit in the dash or if you need to pry or pop it out? Thanks fro any help!
Old Apr 22, 2004 | 05:18 PM
Comp97GSR's Avatar
Default Re: Does anyone know how to remove climate controls from ITR? (ITRITR)
Pop out the defrost and the hazard switches
Old Apr 22, 2004 | 05:34 PM
ITRITR
Guest
Posts: n/a
Default Re: Does anyone know how to remove climate controls from ITR? (Comp97GSR)
I got the 2 bolts out, but the unit is still having a hard time coming out. Any suggestions? Is there anthing else that needs to be disconnected?
Old Apr 22, 2004 | 06:21 PM
AW's Avatar
AW
Default Re: Does anyone know how to remove climate controls from ITR? (PHXITR)
Did you disconnect the cable underneath the passenger side dash that the heater switch cable is connected to?
AW
twentyhurtz
Dec 8, 2008 01:19 PM
Baron55
Jul 17, 2005 09:43 AM
Zoso1977
Nov 6, 2004 10:57 PM
LSegHatchy
Aug 4, 2004 06:45 PM
N~FaMouSKhMerBoi
Jan 28, 2004 04:04 PM
