Pic request: Back of JDM HID headlights
I got a 95 GSR that's getting a JDM ITR HID conversion.
The problem is that the factory HIDs dont fit correctly.
Can someone with OEM HIDs snap a picture of the back of the headlight while in the car. I want to see how you got them to fit or what you removed.
Thanks alot
Thanks alot
depending if the individuals who did your conversion wielded everything right.. or else you might want to check for clearance on the ballasts to see if its hitting anything or you might want to trim some of it off..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Who Said »</TD></TR><TR><TD CLASS="quote">I got a 95 GSR that's getting a JDM ITR HID conversion.
There's your problem right there- the 94-97 ABS units are different from the 98-01, thus the passenger side HID ballast won't fit without modifying the location of the ABS unit. Do a search, it's been covered before.
Nishant
Feb 2, 2004 10:10 AM
ITR 2K
May 1, 2002 04:59 PM
