How do you remove/install bumper lenses on a 95 Accord?
Whats up. I got a pair of JDM bumper lenses for my 95 Accord. Anyone know how to remove the stock ones and install the JDM ones? Thank you.
remove the bumper an there are i think 3 screw under there,on each side...but it has to come off before anything...
thats bout all i know bout it just thought to help you out at the beginning
if they are a direct bolt on which they should be.. go to your grill[lower] ,on the top left and right there are cut out squares at the inside of each light.take a very long screwdriver[phillips] and find the whole[u should be able to see it] then unscrew it...the light will then ba able to be pulled outcloser to the tag....disconnect the harness and re-install the jdms..good luck.
S2KILLA
Nov 29, 2007 11:42 AM
hollywood30002
Jun 13, 2004 08:11 AM
Grouchie69
Dec 19, 2003 11:35 PM
99SportSedan
Jun 28, 2001 03:25 AM
