high rev pinging
Old Apr 22, 2004 | 12:35 PM
dip-set's Avatar
Default high rev pinging
its no more than a 96 ls(b18b),stock motor, only a k&n filter on the end of the stock intake tube,and catback exhaust...
lately when i get on it i hear a slight ping from the vavetrain,at about 4000,5000 rpm.sometimes worse than others sometime intermitent...theres no valve tap although i may need a valve adjustment...what else may cause this ping...timing is 16 degrees,i run 89 octane,and i notice this happening more when its hot outside...right now im running ngk coppers,(stock application)..i forget there number...any ideas ?
Modified by b18b-se at 11:37 AM 4/28/2004
Old Apr 28, 2004 | 07:37 AM
dip-set's Avatar
Default Re: high rev pinging (b18b-se)
i guess no one has the slightest idea..
Old Apr 28, 2004 | 08:37 AM
CHEETAH's Avatar
hot temparature with 89 octane fuel and 16 degree advance will ping on heavy loads. Its ntohing abnormal.
if you dont want pinging then use 91 or 93 octane.
greg
Old Apr 28, 2004 | 11:49 AM
dip-set's Avatar
Default Re: high rev pinging (CHEETAH)
thanks greg...i didnt think my stock ls would benefit from higher octane. gas unless need for other reasons.
what if it still does the same with 91..theres no 93 round here other than sunoco ultra 94...would going to a colder plug help? can not getting enough air into the motor cause this also..i.e. having a catback exhaust and stock intake...just trying to clear up ideas that have been run by me...
Old Apr 28, 2004 | 12:51 PM
LSVTEC 91 Civic's Avatar
Banned
You're probably too lean, If you have a fuel controller you can richen up the RPM points that are pinging...
Try that.
Old Apr 28, 2004 | 01:21 PM
dip-set's Avatar
Default Re: (LSVTEC 91 Civic)
did u not read the post....STOCK LS OTHER THAN A K&N ON THE OEM INTAKE TUBE AND A CATBACK...geezus...why would i have a fuel controller on a stock motor with no mods...
Old Apr 28, 2004 | 01:27 PM
Banned
Default Re: (b18b-se)
STFU, Don't yell at me you moron, last time I checked.. You're the one with the PROBLEMS.
Old Apr 28, 2004 | 04:47 PM
dip-set's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">STFU, Don't yell at me you moron, last time I checked.. You're the one with the PROBLEMS.</TD></TR></TABLE>
correct,car problems..while u are obviously incompetent and didnt read before you replied,i mean u did read but your incompetence kept u from comprehending what u were reading and led you to replying with such an idiotic suggestion...
now moving on,thanks again greg for the suggestion..
Old Apr 28, 2004 | 11:12 PM
b16vtecsol's Avatar
i think you both need to chill out. just get a fuel pressure regulator and up your fuel pressure a couple of psi. might be a little rich down low but you be fine up top. it's about 85 franks for b and m with the gauge and takes about 5 minutes to install.
Old Apr 29, 2004 | 05:47 AM
CHEETAH's Avatar
try upping the plugs, bkr6e13 ngks. back the timing a bit if still pinging, set it to 15 and increment by 1 til it pings then back it down.
hess has 93, exxon has 93 ... i'd experiment with 93 first before doing everything if it stops pinging then you def had crappy fuel and need to stay away from the 89.
greg
Old Apr 29, 2004 | 07:54 AM
dip-set's Avatar
exxon up here in north jersey only goes up to 91,hess never bothered looking at,but i"ll give the gas a shot first,then new plugs,correct timing if need be,and lastly but not least,get a fpr and guage...thanks guys
is just a lil hard to understand why a stock ls would need 91 or even 93,shouldnt it have been fine with 89 which is 2 higher than the factory recomended 87...
SoFresh1189
Jan 26, 2010 02:32 PM
tsdenny
Aug 21, 2004 01:55 PM
dip-set
Oct 8, 2003 06:03 PM
sal_blkej2
May 20, 2003 01:20 PM
dip-set
Jan 15, 2003 04:53 AM
