check engine code signal= 10......
Old Apr 22, 2004 | 12:26 PM
9WON4's Avatar
Default check engine code signal= 10......
I know it's the IAT, but why am i still getting a 10 code if I have used my friend's old sensor as well. Is the only way to get rid of my check engine light , is to buy a brand new sensor? Could it be something else, like my EVAP purge solenoid? And do I NEED the "scan tool" that the factory book is telling me to use, to ensure that my IAT is working properly?......is the IAT sensor expensive?
Thanks Everyone!!!
Old Apr 22, 2004 | 12:32 PM
Grimm's Avatar
Default Re: check engine code signal= 10...... (kidkanedtx)
i get code ten at least once every 2 weeks, I reset the ECU (after assuring it's code ten) and go about my day, my friend had his sensor melted and that was causing his, I haven't checked mine outyet, so if there is something else I'd like to know as well.
Old Apr 22, 2004 | 12:38 PM
-Trinitron-'s Avatar
check for vacuum leaks... I threw a IACV code when my cruise control line slipped off...
Old Apr 22, 2004 | 12:39 PM
Grimm's Avatar
Default Re: check engine code signal= 10...... (-TRINiTRON-)
can you explain this a bit, I run with no A/C ( I removed it) so one of the vacum hoses could be causing this?
Old Apr 22, 2004 | 05:28 PM
9WON4's Avatar
i do have a super charger, i guess i could check.
Old Apr 22, 2004 | 05:30 PM
9WON4's Avatar
no, i really need to know more info........can anyone help??
Old Apr 22, 2004 | 05:38 PM
pdiggitydogg's Avatar
check the under-dash fuses
that happened to me over the winter and that was the cause of it (blown fuse)
REDREXMANB16
Nov 23, 2006 09:54 PM
turbojdm521
Jun 15, 2003 09:57 AM
b18c1VX
Mar 20, 2003 10:09 PM
