JDM JDM JDM - ???
Old Apr 22, 2004 | 11:27 AM
BoBoChan's Avatar
Default JDM JDM JDM - ???
I have some questions bout engine swappin so here it is. If you are going to answer, can you plz copy the question or quote it and then answer. thanks.
1. How much does labor for engine swappin cost? ::Gimme A Range From Lowest to Highest::
2. Are the JDM motors built for the right side, if so how can i get them installed into the left side?
3. How long will the car be in the shop for an engine swap?
4. Will a swapped GSR in a 99 civic out perform the stocked gsr on a teggy?
5. Does it matter if the car is an auto b4 the swap to a 5-speed?
6. Will i have to get new gauges for the car?
7. When swappin, everything goes rite? so.. i could buy a $3k car with 150k miles and swap with a 30k mile engine and it will run fine.
Old Apr 22, 2004 | 12:20 PM
Turbogixxer's Avatar
Default Re: JDM JDM JDM - ??? (BoBoChan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">1. How much does labor for engine swappin cost? ::Gimme A Range From Lowest to Highest::</TD></TR></TABLE>
six to thirteen hundred$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">2. Are the JDM motors built for the right side, if so how can i get them installed into the left side?</TD></TR></TABLE>
They change the car design not the motor design
It is the same motor (casting) as USDM but the mod the car and wiring harness to work on the motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">3. How long will the car be in the shop for an engine swap?</TD></TR></TABLE>
few days to a few weeks pending on the shop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">4. Will a swapped GSR in a 99 civic out perform the stocked gsr on a teggy?</TD></TR></TABLE>
Bench racing
A lot of things comes into play like driver Car weight etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">5. Does it matter if the car is an auto b4 the swap to a 5-speed?</TD></TR></TABLE>
more work to convert the auto to a manual but it can be done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">6. Will i have to get new gauges for the car?</TD></TR></TABLE>
nope your stock guages will work
If your car does not have a tach
You should get one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">7. When swappin, everything goes rite? so.. i could buy a $3k car with 150k miles and swap with a 30k mile engine and it will run fine.
if the swap is done right then yes
Old Apr 22, 2004 | 12:56 PM
BoBoChan's Avatar
awesome..
here i come with teh SWAP!! wootzor
1player2nv1
May 3, 2010 10:35 AM
pliskin679
Apr 15, 2009 06:00 AM
knowles_101
May 15, 2006 02:06 PM
redsled00
Sep 30, 2003 05:11 AM
