ECU HELP!!
Old Apr 22, 2004 | 10:13 AM
91civichatch's Avatar
Default ECU HELP!!
I plan on swapping a dohc zc engine in my car. My question which is the best ecu to use with it? The car is a dx and I know I have to wire for mpfi. Also any websites I can go on to look for performance parts for it or do I shop for a certain year car that has parts to fit this type of setup?
Old Apr 22, 2004 | 10:15 AM
EG8R's Avatar
Default Re: ECU HELP!! (91civichatch)
PG7 for a USDM ECU. I believe the ZC ECU is a PM7....
Old Apr 22, 2004 | 10:19 AM
HamiltonRex's Avatar
Default Re: ECU HELP!! (skelly ed666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 &raquo;</TD></TR><TR><TD CLASS="quote">PG7 for a USDM ECU. I believe the ZC ECU is a PM7....</TD></TR></TABLE>
Correct.
-Eric
Old Apr 22, 2004 | 10:43 AM
junkyardRx's Avatar
http://www.zcspeed.com/zcspeed.htm
http://www.zcr.com
yes the ecu you would need would either be the "real" ecu PM7 from a ZC in japan. Or you can go with PG7, make sure you get the one from an 88-89 usdm integra or it wouldn't work. also it would be wise to swap the cases of the ecu to properly mount the ecu in your car. i made a how to if you need it.
https://honda-tech.com/zerothread?id=826846
Old Apr 22, 2004 | 02:21 PM
MatHadder's Avatar
I would personally suggest a PM6 because it has a seperate ROM chip for the fuel and timing maps, which makes it easier and cheaper to chip. However, if you arent planning on putting a chip into it, go with the PM7 or the PG7
Cambo88zc
Jan 21, 2006 05:07 PM
vega_ROCKS
Oct 31, 2005 03:24 PM
South Bay Surfer
Feb 29, 2004 12:10 PM
vtec_head
Oct 2, 2003 07:59 AM
kenepo
Mar 18, 2003 01:13 AM
