Shifter falling through floor?
Old Apr 22, 2004 | 10:05 AM
Blazeone's Avatar
Default Shifter falling through floor?
I have a skunk 2 SS, with urethane busings on my car. When i put the SS in it seems to fall through the floor and rest on my exhaust, i replaced that white bushing that goes around the ball and it seemed fine for a few months. Now the shifter has dropped completely through the floor and rests on the exhaust, and the only way to drive is to hold the shifter up(PITA btw).
Am i missing something here? Why is it falling through the bottom of the car? Should i just try another white ball bushing?
Old Apr 22, 2004 | 10:13 AM
PlastikOwl
Guest
Posts: n/a
Default Re: Shifter falling through floor? (BlazeONE)
look under the car and see that everything is bolted up. Maybe you broke a bushing down there?
Old Apr 22, 2004 | 01:15 PM
Blazeone's Avatar
Default Re: Shifter falling through floor? (PlastikOwl)
Checked and nothing so far, looks like the shifter ball is too small and falls through the floor...
Old Apr 22, 2004 | 05:36 PM
Dr Pooface's Avatar
The shifter ball sits in the white bushing, which in turn is bolted to the car with a bracket below. Sounds like you're missing something. Take some pics.
Old Apr 22, 2004 | 06:22 PM
B2FiNiTY's Avatar
There isn't much holding the shifter together.
1 main bolt on the bottom. 2 nuts and 2 bolts holding the shifter and plate together.
Old Apr 23, 2004 | 03:53 PM
Slater's Avatar
http://www.fastlineperformance...r.htm
Check the install instructions on our site - they are easy to follow with a pic for reference. In particular look at steps #5, 6, and 9. If you left out any of the stock parts that is your problem (either the rubber boot or the metal plate it sounds like).
The instructions are specific to our Road Racing shifter, but the install instructions are bascially the same for your Skunk shifter.
Let us know what you find.
- Slater
Old Apr 23, 2004 | 06:11 PM
all stock's Avatar
Default Re: Shifter falling through floor? (Slater)
I had a similar problem. I put washers between the bolts which kept the bushing in place.
Old Apr 23, 2004 | 11:10 PM
TypeRPaul's Avatar
Default Re: Shifter falling through floor? (all stock)
i had the identical problem with my c's shifter, im trying to remember what , but ur installing one piece upside down...i'll try to remember and post up tomarrow
Old Apr 26, 2004 | 08:53 AM
Blazeone's Avatar
Default Re: Shifter falling through floor? (TypeRPaul)
Ok well, i did some investigation and found out that the ball had actually fallen through that plate.
According to the diagram:
I am missing piece #1, and assuming that the #8 is the white plastic bushing that hugs the ball. That is wierd, since that the #1 piece never camne with the car, hmm I have it all held togethr by tie strpas right now for a temporary fix
Old Apr 26, 2004 | 08:57 AM
A+Foreign_Dave's Avatar
Tighten your bolts billy
Old Apr 26, 2004 | 11:26 AM
Blazeone's Avatar
Default Re: Shifter falling through floor? (A+Foreign_Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A+Foreign_Dave &raquo;</TD></TR><TR><TD CLASS="quote">Tighten your bolts billy</TD></TR></TABLE>
If you are talking to me, the bolts are cranked all the way.
Old Apr 26, 2004 | 12:45 PM
blktyprgrl's Avatar
dont tighten them too tight... my shifter is loose b/c i let my "eager" coworker help out when changing the shifter out.. he snapped those little bolts in two....
i'm guessing the ball is too small... i have a different shifter but no white plastic thing and it stays put for the most part, it may be a combination of the two..
fleabag
Honda Civic (2001 - 2005)
Aug 17, 2012 05:24 PM
puertoroc7976
Aug 11, 2006 08:02 PM
vwtohonda
Aug 7, 2006 08:55 AM
slash00R
Nov 1, 2004 07:23 PM
Eatvtec97
May 20, 2002 12:56 PM
