Type-R TB on a D16Y8 IM ???
Is there anyway to fit a TypeR TB on a D16Y8 IM ? If yes what it require and is it difficult to do it... gasket, TPS sensor, coolant line ???
Thanks guys !
Mat
Thanks guys !
Mat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacked from Spade's SOHC upgrade thread »</TD></TR><TR><TD CLASS="quote">Any throttle body for an H series B series or D series are interchangeable, with one catch; you need to pay attention to where your IACV (idle air control valve) is. For example, the D16Y8 (96-00 EX) has different mounting points and uses a 2 wire IACV. On the automatic, the IACV (which is a 3-wire) is mounted on the throttle body and the manual has the IACV mounted on the back of the intake manifold. The later model VTEC B series and B20 (CRV) throttle bodies are all 60mm in size. Except for the ITR, this is 62mm. The H22 is also a 60mm throttle body, while the Civic gets a puny 56mm. Make sure when you add the larger throttle body that you port match (make the holes the same size) the opening of the intake manifold.
superdavebigD
Jun 11, 2016 11:42 AM
lilfed857
Nov 21, 2014 09:56 PM
civicmatt
11
Jul 9, 2003 06:40 PM
