Wiring for projectors?
Old Apr 22, 2004 | 08:20 AM
Geone's Avatar
Default Wiring for projectors?
I just bought some projector halos for my civic 92-95 hatch. The box says eagle eyes innovative performance trends. There was a complete wiring with the kit i figured out everything but the problem is the one headlight has a male connector the other one a female connector and the wiring has two females and one male. If i connect the headlamps to the wiring one female connector lefts. Where is it supposed to go? on the wiring of my car? but it is also female... Any ideas would be greatly appreciated. Thank you.
Old Apr 22, 2004 | 08:34 AM
Luserkid's Avatar
Default Re: Wiring for projectors? (Geone)
How many wires did you have?
What you could do is say **** the connectors (i dont like them personally anyway) and just clip them. Then if you need longer cord go buy some gauge wire that big. Next (after you clip the wirers longer) you could tap one into the side lights (theres 3 wires there, green, another color and black, tap the other wire) and then set the ground wire somewhere.
If you have another wire on the projectors then its either power or for when you hit your high beams. If its power just hook it up to your batt. If its for the high beams im not sure where to hook it up (sorry).
Hope that helps.
Old Apr 22, 2004 | 12:59 PM
Turbo_EJ's Avatar
The one female connector connects into your origional headlight harness, but only on one side.
Old Apr 22, 2004 | 03:16 PM
vtekstorm's Avatar
Default Re: Wiring for projectors? (turboEGdotCOM)
the metal prongs on the connector from the stock harness on the car can be pulled out of the connector hope that helps u out, and if they arent on the connect check the bulb they might be stuck on them. but those prongs can be poulled out
Hung_Lo
Jun 17, 2007 06:55 PM
prelude1897
Audio / Security / Video
May 3, 2006 03:39 PM
hondaboy90
Mar 28, 2006 02:02 PM
93VAhatch
Jan 13, 2003 07:45 PM
