Stock Cat on 00 SI
Old Apr 22, 2004 | 05:27 AM
Y2KEBPSI's Avatar
Default Stock Cat on 00 SI
Are the three bolts or studs fastened to the flange on the stock cat? I got one of the nuts off the other day but the other two rounded off. I was going to cut them off but didn't know if the bolts or studs were actually attached to the flange or not.
Anyone know?
Old Apr 22, 2004 | 07:34 AM
H22A EG6's Avatar
Default Re: Stock Cat on 00 SI (Y2KEBPSI)
pretty sure they are just bolts that are sliped in there they are not attached
Old Apr 22, 2004 | 07:58 AM
jimee pop's Avatar
Default Re: Stock Cat on 00 SI (H22A EG6)
yes they are! pressed into the flange... your screwed
Old Apr 22, 2004 | 08:24 AM
Y2KEBPSI's Avatar
Default Re: Stock Cat on 00 SI (jimee pop)
That's what I figured since they are really rusted on but the one came loose without breaking.. No biggie... I was just trying to get the cat off to use on another b-pipe..
Old Apr 22, 2004 | 01:09 PM
-Trinitron-'s Avatar
they don't come off...any test pipe will just use the 3-hole flange, then just use regular nuts and bolts.
sebTeggy
Oct 17, 2011 08:50 PM
...rohit
Feb 27, 2010 07:47 AM
asmallsol
Aug 12, 2006 05:54 PM
Aaron M
Apr 7, 2003 08:03 AM
