OBD0 ZDYNE users running an OBD1 motor?
can I use my stock D16a6 obd0 distributer on a B18C obd1 motor? MY problem is solved if I can do this...or do I have to use a a dist. from an obd0 B16?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6Turbo »</TD></TR><TR><TD CLASS="quote">OK, so I can use one off of a 91 B18B integ?</TD></TR></TABLE>
yeah but u need to break off one of the tabs that the dizzy bolts up threw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turboic »</TD></TR><TR><TD CLASS="quote">cant use an ls dist. on a vtec head. you must use the obd0 b16a dist.</TD></TR></TABLE>
thanks for the info. (not doubting you) , I'm just wondering if anyone else out there can confirm this.
"AN LS (B18B) DISTRIBUTER WILL NOT WORK ON A B18C HEAD."
other's please confirm...
ok, I've got another question about using the zdyne on an obd1 B series motor.
So I would also need to use a 1 wire 02 sensor and forget about the knock sensor as well right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCow »</TD></TR><TR><TD CLASS="quote">Also, keep in mind that some of the OBD0 ECUs (maybe all?) had an external PA sensor. You'll need that too.</TD></TR></TABLE>
PA sensor, I'm sorry...what's that?
other's please confirm...</TD></TR></TABLE>
Too much timing!! 30+ advance I do believe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy »</TD></TR><TR><TD CLASS="quote">needs to be a B series distributor, sorry
Rob</TD></TR></TABLE>
wrong
but somehwat the right idea
2G tegs have the LS motors and they are B series
the 88-91 civic crx hf and SI dizzy are the same as those... i had a LS for spare for my si dizzy and its the same ****
so basically yes u need a OBDO Si dizzy or LS dizzy
wrong
Power Rev Racing
Jul 27, 2005 05:12 PM
kingkong
May 9, 2005 11:19 PM
