B20 Vtec with JE pistons
Old Apr 21, 2004 | 08:57 PM
B16Hatchcx's Avatar
Default B20 Vtec with JE pistons
I am in the process of putting a B16 head on a B20 block with JE 11.5:1 pistons. Since the bore size on the head is 81mm and the bore on the block is 84mm, will the after market pistons hit the head? Thanx
Old Apr 21, 2004 | 08:59 PM
99blackcivicSi's Avatar
Default Re: B20 Vtec with JE pistons (B16Hatchcx)
it isn't the sides of the chamber you should be worried about it is the valves, make sure you clay the motor since B20/vtecs are iffy on clearence anyway
Old Apr 21, 2004 | 09:07 PM
B16Hatchcx's Avatar
Default Re: B20 Vtec with JE pistons (99blackcivicSi)
I'm running skunk 2 stage 2 cams. Do you think this will be a problem? How high should I rev??
Old Apr 21, 2004 | 09:57 PM
thats all up to u man, i would just clay the motor if i were you.
Old Apr 21, 2004 | 10:02 PM
DOHCtorTHRUST's Avatar
if the head isnt super milled(i know, lame term) you shouldnt have to worry about the pistons hitting the valves... the cams are big but it will have a good amount of clearence....
you dont have to worry about the piston hitting the head because of 84mm sleeves...the chamber area has enough room to clear it.
Old May 3, 2004 | 07:57 PM
B16Hatchcx's Avatar
Default Re: B20 Vtec with JE pistons (DOHCtorTHRUST)
Is there anything I should do to the block before installing the aftermarket pistons?
Old May 3, 2004 | 08:08 PM
xerox445's Avatar
are you installing them? or a machine shop? u might want get it honed.....
jksmith
Dec 14, 2010 11:20 AM
ZedEx
11
Jul 10, 2005 09:18 AM
EGRhatch
Jan 8, 2005 04:29 AM
ultraspeed2nr619
Oct 28, 2001 07:17 AM
