Intake Package for top end
Old Apr 21, 2004 | 07:13 PM
Crackerballer's Avatar
Default Intake Package for top end
Wassup guys, Ok I have a Skunk2 intake mani, im getting a 3 inch mandrel bent short ram intake off ebay, my TB will be bored over to about 64mm, question is, this so far is more of a top end package, are the skunk2 cams a good complement to this kit? I want more of a decent mid range, but just awesome top end, and I plan to upgrade the valve train so I can rev to like 85-8700 or so.
Can I go witht he ITR valve train, or Skunk2, etc. The reason I ask, is my question is a little too specific for the parts I have listed to search.
Oh I also want really good throttle response. Thanks
Old Apr 21, 2004 | 07:18 PM
Kendall's Avatar
For any cams, you should run the manufacturers recommended valvetrain. I think you will do better up top, but I recommend raising the compression a bit to help out. a Spoon headgasket is a good start if you don't want to tear down the block.
Old Apr 21, 2004 | 07:22 PM
FragSyndrome's Avatar
skunk2 cams are nearly identical to the itr cams so you can use the itr valvetrain with it.
Old Apr 21, 2004 | 07:29 PM
Kendall's Avatar
Default Re: (FragSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FragSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 cams are nearly identical to the itr cams so you can use the itr valvetrain with it.</TD></TR></TABLE>
It depends heavily upon which Skunk2 cams they are. With any Skunk2 choice, however, they are more agressive than ITR/CTR cams and will not not perform optimally unless higher compression can be obtained. About the valvetrain issue, Skunk2's Stage 1 cams should work with stock ITR valvetrain, however I don't recommend doing so because something as simple as a misshift will spell certain doom for the engine. Skunk2's Stage 2 cams will require upgraded valvetrain, period.
Old Apr 21, 2004 | 08:13 PM
yea i plan on going about 11.5:1, but thats way down the line, i think after the mani, tb, intake, i will go for header cat exhaust,
martyball619
May 21, 2010 03:31 PM
EF_FEVER
10
Jun 2, 2008 01:00 PM
[JFG]RACING_EM1
Mar 13, 2007 12:24 AM
2000GSR
Apr 4, 2003 09:29 AM
HX_Guy
Dec 23, 2001 06:19 PM
