(Searched) D16Y7 stock camshaft specs
Old Apr 21, 2004 | 06:56 PM
HiVolume.com's Avatar
Default (Searched) D16Y7 stock camshaft specs
I can't find the full specifications for the D16Y7 stock camshaft. Can anyone point me in the right direction or have the information?
Thanks!
Old Apr 23, 2004 | 01:36 PM
Default Re: (Searched) D16Y7 stock camshaft specs (HiVolume.com)
bump for the info!
Old Apr 24, 2004 | 11:07 AM
Anyone have the firing order at least??
Old Apr 24, 2004 | 11:11 AM
rexandfx's Avatar
1-3-4-2
Old Apr 24, 2004 | 11:20 AM
rexandfx's Avatar
Default Re: (Searched) D16Y7 stock camshaft specs (rexandfx)
Camshaft Endplay------------0.02in. ------0.5mm
Camshaft to holder oil clearance--------0.0006 in.---------0.15mm
Total runout-------------0.002 in.-------------0.04mm
Camshaft lobe height Intake------1.3897 in.----------35.299mm
" " " Exhaust----1.4678 in.----------37.281mm
Torque Specs.
Camshaft sprocket bolt--27 ft. lbs.------37Nm
Bearing journal-to-cylinder head
6x1.0mm bolts-------104 in. lbs.-----------12Nm
8x1.25mm bolts------16 ft. lbs-------------22Nm
CR-X_B20
Aug 16, 2017 12:54 PM
sh4mr0ck
Aug 14, 2009 09:49 PM
dropthonda
Dec 16, 2002 01:37 PM
