back timing belt cover
After installing my cam gears I had to remove the back timing belt cover because the gears were rubbing against it. I have all the other covers on, but I wish I could have my back cover as well since there is a small gap on the side where a rock could POSSIBLY get in and mess things up. It would be very dificult, but certainly possible. Has anyone have to remove the back timing belt cover or modify it after installing cam gears?
[Modified by 1fastGSR, 3:32 AM 10/31/2001]
You shouldn't have to remove the cover... just trim it, and install it. Test fit it to see if it clears the gears. It's a pain in the *** because you'll have to yank the cam gears off to get to it. oh well...
[Modified by Mike K, 11:41 PM 10/30/2001]
joemama
Jun 12, 2001 08:45 AM
