Integra LS Pisotn Rod Bearings Color
Hi I was wondering does the rod bearings color matter? I have a 94 Integra LS and is putting in some b16a2 pistons, I need another persons point of veiw?
If anyone has changed these what color do I need thanks
Modified by milton at 2:17 AM 4/22/2004
YES!!,Bearing colors do matter.Replace the the bearings with the same colors that came out.Did you mark where they came from when you tore everything apart?
I havent taken them out yet, I didnt want to wait too long to get them, thats why I was wondering if all other ls 94 the same or different, because I wanted to get everything ready for it
When you take it apart mark the rods.With a centerpunch or something,so that you know which rod came from which cylinder.The bearing color is on the side of the bearing.That is what bearings you need.Try searching on this I'm sure it has been covered a million times.
