How do they determine a redline?
Old Oct 30, 2001 | 05:50 PM
LakeMountLude's Avatar
New User
Default How do they determine a redline?
Does Honda set a cars redline by what it can handle? Or does it set a redline by where it stops making power? Is it that bad to go over redline? I would think it would be..
Old Oct 31, 2001 | 06:49 AM
LudeBehavior's Avatar
New User
Default Re: How do they determine a redline? (LakeMountLude)
Redline is just a saftey standard on the tolarancec of the engines. My 4g lude stops accelrating at 7.5rpm but red lines after that. You can up your redline by building your top end stronger so it can take more abbuse. Normally before you hurt your engine you will run into fuel cut off or rev limiter to stop it from happening.
Old Oct 31, 2001 | 10:47 AM
illusion's Avatar
Default Re: How do they determine a redline? (LudeBehavior)
actually that is the correct redline. the stock tach is off.
IA95civicDX
13
Oct 25, 2005 05:10 PM
200cs
Sep 12, 2005 01:08 PM
Behan
May 16, 2003 09:18 AM
itr1244
Nov 1, 2002 05:29 AM
PiYoImuT
Jun 29, 2001 10:57 AM
