Check Engine Light comes on only after hitting 6000rpms
Old Apr 21, 2004 | 02:46 PM
rad_thundercat's Avatar
Default Check Engine Light comes on only after hitting 6000rpms
this happened to me last night. I was driving with 2 other people in the car and after hitting 6000rpms, the fuel cut off as if i was hitting the rev limiter and the check engine light came on.
I pulled over, stopped the car, then started it up again with no Check Engine Light. ok, cool. I drove around for a bit keeping it under 4000rpm's and still no CEL. ..getting curious and anxious I brought it up to 6000 and the same thing happend -fuel cuts off and the CEL comes on.
I have a '94 gsr with ~140,000 miles. The car drives fine as long as i keep it under 6000rpms (when the secondaries come in). Anyone have any ideas? I wanted some opinions before i start taking it around to shops
thanks!
Old Apr 21, 2004 | 03:43 PM
RidinStock's Avatar
Default Re: Check Engine Light comes on only after hitting 6000rpms (rad_thundercat)
https://honda-tech.com/zerothread?id=838322
that should help you more than enough.
Old Apr 21, 2004 | 03:45 PM
shamoo's Avatar
Will you make something up for me please?
Why don't you just check the codes? It could be a hundred different things. But since your light comes on, it makes everything so much easier.
Just run the code and see what it is.
Old Apr 21, 2004 | 07:31 PM
94gsr4dr's Avatar
Default Re: Check Engine Light comes on only after hitting 6000rpms (shamoo)
I had the exact same problem at the ITR EXPO last year, but it only popped up after driving at a constantly high rate of speed, just reset the ecu.
Old Apr 21, 2004 | 07:35 PM
frenchy's Avatar
Default Re: Check Engine Light comes on only after hitting 6000rpms (94gsr4dr)
i bet you get a 22 - you reset the ecu by unplugging the battery right?
Old Apr 21, 2004 | 07:53 PM
m R g S r's Avatar
Default Re: Check Engine Light comes on only after hitting 6000rpms (frenchy)
I got that code, 22 right after I boosted hard through the top of 4th gear. It wasn't a fuel cut, but it stopped pulling hard, and I noticed that the tach would jump around from like 7-8k. I added a little oil (it was a little low) and then the problem went away. Well for a day at least, the next day, my engine blew. hahahah It wasn't because of the code thou, I just overboosted.
Old Apr 21, 2004 | 08:20 PM
frenchy's Avatar
Default Re: Check Engine Light comes on only after hitting 6000rpms (m R g S r)
yeah i get 22 when im real low on oil -
03djmAccrd
15
Sep 25, 2010 04:33 PM
NewEra
Jul 20, 2009 08:13 PM
SiTR
Feb 14, 2008 04:19 PM
SlammedBlackGSR
Nov 20, 2006 02:04 PM
CaliRockrr
Nov 26, 2005 04:37 PM
