Tips to get shock fork lined up with lower control arm?
Old Apr 21, 2004 | 02:40 PM
PabloDiablo's Avatar
Default Tips to get shock fork lined up with lower control arm?
I am doing a spring/shock swap in my '92 civic. Everything went well, from removal to assembly until I have to put in the bolt that holds the fork to the lower control arm (front). I've been wrestling with it for a few hours and no luck. I've tried using a floor jack to line them up, I once got a screwdriver in the holes but couldn't line them up enough to put the bolt in. Any tips?
Thanks in advance
Old Apr 21, 2004 | 02:41 PM
DAguyLS's Avatar
get a friend to help
me and my buddie had no probs at all
Old Apr 21, 2004 | 02:43 PM
Default Re: (slamdcivic)
Just moved to LA, I don't know anyone. Any other tips?
Old Apr 21, 2004 | 04:10 PM
haccord2.2's Avatar
Default Re: (PabloDiablo)
Well when I do this all I do is use my pry bar and put it in the front shock fork and turn the shock fork whatever way you need to to get the wholes to line up and then slide the bolt in. Well I hope this helps. Jordan.
Old Apr 21, 2004 | 04:11 PM
97civicdx's Avatar
Default Re: Tips to get shock fork lined up with lower control arm? (PabloDiablo)
unbolt the lower ball joint to free up the lower control arm.
Old Apr 21, 2004 | 04:45 PM
Default Re: Tips to get shock fork lined up with lower control arm? (97civicdx)
Thanks for the advice guys! I actually loosened the upper control arm all the way to allow the lower control arm to droop just a little more without me pushing it down. Then after another 20 min. of struggling, I got it. The other side came together without a hitch. At first I was going insane because the left side seemed at least an inch higher than the right! But I let the car roll a few feet and jumped up and down on the doorsill to get the suspension to settle and now they're even, I guess it was the way the car was lowered from the jackstands the frame and the suspension were torqued a little and that caused the initial difference in height. All done with the front, gonna do the back tomorrow morning, plus new brake shoes (that should be fun)...
Old Apr 21, 2004 | 05:05 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
I would disconnect the knuckle from the lower arm and start from the inside and work your way out. Don't tighten everything (or anything) until all the bolts are through. You could also loosen the fork from the shock and re-adjust it from there... Good luck.
daniel-em1
Suspension & Brakes
Jun 13, 2011 02:41 AM
corkss
10
Mar 19, 2009 07:00 PM
butter99
27
Nov 28, 2008 04:53 PM
superman3503
May 25, 2006 03:26 PM
PabloDiablo
Apr 21, 2004 11:30 PM
