Dyno'd the R
Old Apr 21, 2004 | 12:51 PM
JOEP's Avatar
Default Dyno'd the R
Dyno'd the car about 2 weeks ago.
Will post the print out soon....
Mods so far...
2000 PY Type R 30,000km
AEM CAI
Power steering belt removed. (Removed it on 3rd run and got a 5HP increase and about 8 ft lbs more!!)
Timing 18 degrees.
Put (corrected) 170.5 HP to the wheels and 118 ft lbs.
Just bought and installed the Comptech header (not the race header) and in about a week my Comptech 7lb aluminum flywheel arrives. Going back to the dyno with the header and will go back again once the flywheel is in to see the difference in results. Will keep you all posted.
The flywheel is going to be installed for free by Acura dealer. They need to replace 5th gear synchro in tranny which is still under warranty so I figured getting a flywheel installed since the tranny is out is a good time to do it.
Thanks.
Old Apr 21, 2004 | 12:54 PM
RTW DC2R's Avatar
nice, and I knew my butt dyno wasnt lying when I removed my PS belt. Definitely notice it.
Old Apr 21, 2004 | 05:13 PM
JOEP's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">nice, and I knew my butt dyno wasnt lying when I removed my PS belt. Definitely notice it. </TD></TR></TABLE>
I havent put it back on since...
Old Apr 21, 2004 | 05:30 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: (JOEP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOEP &raquo;</TD></TR><TR><TD CLASS="quote">
I havent put it back on since... </TD></TR></TABLE>
Yes, but is that small amount of gain worth ease of driveability? I drove my friends without the ps belt and it was not worth it to both of us. We put it right back on.
I just don't see a big advantage to doing that. Put the belt back on and get some adjustable cam gears and the get it dyno tuned. I got 178whp and about 125tq with just cam gears and CAI. My VAFC was left untuned at that time.
Old Apr 21, 2004 | 05:36 PM
fuck honda-tech's Avatar
Default Re: (Gee3)
u get use to it
Old Apr 21, 2004 | 05:49 PM
raw01's Avatar
New User
Default Re: Dyno'd the R (JOEP)
Those #'s are okay.... but not spectacular. My 2001 put down 174.6 and 123 with just timing and the belt removed. That was with only 8000 kms on the car... I suspect that it is putting down more now with the added kms.
Nice #'s... but not enough Joseph! You better hope the parts show up soon before the car comes down off the stands! Ding, Ding!!!!!
Old Apr 22, 2004 | 07:00 AM
JOEP's Avatar
Default Re: Dyno'd the R (raw01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raw01 &raquo;</TD></TR><TR><TD CLASS="quote">Those #'s are okay.... but not spectacular. My 2001 put down 174.6 and 123 with just timing and the belt removed. That was with only 8000 kms on the car... I suspect that it is putting down more now with the added kms.
Oh ill bring it buddy, then me and you have a trip to the track!!!!
Old Apr 22, 2004 | 07:05 AM
JOEP's Avatar
Default Re: (Gee3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gee3 &raquo;</TD></TR><TR><TD CLASS="quote">
I just don't see a big advantage to doing that. Put the belt back on and get some adjustable cam gears and the get it dyno tuned. I got 178whp and about 125tq with just cam gears and CAI. My VAFC was left untuned at that time.</TD></TR></TABLE>
Actually I tend to differ, I really like the feel of it without the PS. A bit of a pain when your not moving but other than I like it cause its like I have more steering response. Going hard around corners is much more responsive, you can get a better sense of how much closer to the edge you are and can judge cornering alot better....imoa.
Old Apr 22, 2004 | 07:23 AM
Dr. EKology's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOEP &raquo;</TD></TR><TR><TD CLASS="quote">Dyno'd the car about 2 weeks ago.
Mods so far...
AEM CAI
Timing 18 degrees.
I would kick the timing back a few degrees if I were you. 18 is a little bit much for a stock ITR. If you take a look at your graph I bet you'll see that the lines are pretty choppy, as opposed to being smooth, which indicates that the motor has a bit too much timing. I would set it to 14-16*.
Old Apr 22, 2004 | 07:28 AM
JDM CTR '00's Avatar
Default Re: Dyno'd the R (EKology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology &raquo;</TD></TR><TR><TD CLASS="quote">
I would kick the timing back a few degrees if I were you. 18 is a little bit much for a stock ITR. If you take a look at your graph I bet you'll see that the lines are pretty choppy, as opposed to being smooth, which indicates that the motor has a bit too much timing. I would set it to 14-16*.</TD></TR></TABLE>
Dr. Hovak in the house Gullereeda?
Old Apr 22, 2004 | 07:40 AM
JOEP's Avatar
Actually your right, at the top end my curves start to "break up". Will knocking it back drop HP levels significantly though?
Thanks.
Old Apr 22, 2004 | 07:42 AM
Thanks.</TD></TR></TABLE>
I wouldn't expect more than a 2-4 whp drop, if that.
Old Apr 22, 2004 | 07:46 AM
98cwitr's Avatar
damn i need advance me timing...nice numbers
Old Apr 22, 2004 | 09:36 AM
JOEP's Avatar
Default Re: Dyno'd the R (98cwitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr &raquo;</TD></TR><TR><TD CLASS="quote">damn i need advance me timing...nice numbers </TD></TR></TABLE>
Thanks I actually owe my best bud Alex who helped me out with that.
Old Apr 22, 2004 | 10:09 AM
RockstarJR's Avatar
Default Re: (Gee3)
What kind of dyno are you guys running on? Stock ITR's usually run 160-165+- afew whp... Those #'s seem really high, considering all you have is an AEM and CG's.
Old Apr 22, 2004 | 10:52 AM
JOEP's Avatar
Default Re: (RockstarJR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockstarJR &raquo;</TD></TR><TR><TD CLASS="quote">
What kind of dyno are you guys running on? Stock ITR's usually run 160-165+- afew whp... Those #'s seem really high, considering all you have is an AEM and CG's. </TD></TR></TABLE>
DynoJet...
Old Apr 22, 2004 | 11:03 AM
Opie's Avatar
I have pretty much the same setup as you minus the power steering removed.
I made 171.x hp and 119.x tq with an AEM cai and the Comptech 4-2-1.
Old Apr 22, 2004 | 11:32 AM
^jefs0ng's Avatar
Banned
Nice after driving a while without power steering you almost wonder why people use it; it's almost uncomfortable driving a car with power steering
Old Apr 22, 2004 | 12:28 PM
JOEP's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">I have pretty much the same setup as you minus the power steering removed.
I made 171.x hp and 119.x tq with an AEM cai and the Comptech 4-2-1. </TD></TR></TABLE>
Nice, but I posted those numbers without the the comptech installed, I'll find out what diffference the header makes once I go back this week.
Old Apr 22, 2004 | 12:29 PM
JOEP's Avatar
Default Re: (^jefs0ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">Nice after driving a while without power steering you almost wonder why people use it; it's almost uncomfortable driving a car with power steering </TD></TR></TABLE>
Yeah man, I like it so much better without... mine is never goin back on.
Marlon88
Mar 22, 2005 01:04 PM
JOEP
May 9, 2004 03:00 PM
JOEP
Apr 29, 2004 12:27 PM
01itr518
Jan 16, 2002 05:55 PM
HX_Guy
Jul 28, 2001 02:05 PM
