Is there a way to tell if these are low or high impedance injectors?
Old Apr 21, 2004 | 12:32 PM
Hoosier Daddy's Avatar
Default Is there a way to tell if these are low or high impedance injectors?
They are RC550s. I need low impedance, but don't know if there's a way to tell.
Thanks
Old Apr 21, 2004 | 12:36 PM
ykracing's Avatar
Default Re: Is there a way to tell if these are low or high impedance injectors? (Hoosier Daddy)
measure them with a meter... I think that low impedance ones are a few ohms, and High ones are in the teens.. IIRC
Old Apr 21, 2004 | 12:38 PM
b18bturbo's Avatar
Default Re: Is there a way to tell if these are low or high impedance injectors? (trboCIVICWRX)
whats the part number on the side of hte injector i can tell quickly for you
Old Apr 21, 2004 | 01:07 PM
The seller was an ***, wouldn't even give a part #. All he would say is "bro they work" blah blah.
Thanks anyway guys, I appreciate it
Old Apr 21, 2004 | 01:39 PM
pornstarSR's Avatar
no tell us the part number on the SIDE of the injector and we can figure it out...
Old Apr 21, 2004 | 02:18 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">The seller was an ***, wouldn't even give a part #. All he would say is "bro they work" blah blah.
Thanks anyway guys, I appreciate it </TD></TR></TABLE>
DAmmm you don't even know what you got, come on Nick, this is how people get F'ed from sellers
Edit: Dont forget to send them out to get cleaned and flow tested, you don't want to blow up your motor b.c one 550cc is only flowing at 250cc If you need the place where I sent mine drop me an IM.
Old Apr 21, 2004 | 02:23 PM
boosted hybrid's Avatar
Use a multimeter and set it on the ohm measuring channel to the last setting (200). Take the ends of the terminals and touch the positive/negative terminals on the injector. If they are high impedance, they will read approx. 12 ohms and if they are low impedance they will read 3 ohms.
Old Apr 21, 2004 | 02:34 PM
Default Re: Is there a way to tell if these are low or high impedance injectors? (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">
Edit: Dont forget to send them out to get cleaned and flow tested, you don't want to blow up your motor b.c one 550cc is only flowing at 250cc If you need the place where I sent mine drop me an IM.</TD></TR></TABLE>
I don't have them, assbag. I was gonna buy them but not from this clown.
Old Apr 21, 2004 | 02:35 PM
Default Re: Is there a way to tell if these are low or high impedance injectors? (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Use a multimeter and set it on the ohm measuring channel to the last setting (200). Take the ends of the terminals and touch the positive/negative terminals on the injector. If they are high impedance, they will read approx. 12 ohms and if they are low impedance they will read 3 ohms. </TD></TR></TABLE>
Thanks for the good info I think i'll just wait it out a little and buy some that I know are low impedance. This guy is putting no effort in helping me out, he doesn't even want to send a part #.
Old Apr 21, 2004 | 02:56 PM
Vtec92Civic's Avatar
tell that dude to blow . . . if he doesn't want to help you out by giving you the part # then they prob. won't get sold.
Old Apr 21, 2004 | 03:25 PM
FredoSP's Avatar
good
Old Apr 21, 2004 | 08:12 PM
FredoSP's Avatar
ive gotten a lot of PM about the place, so here's the link for everyone.
http://www.cruzinperformance.com/fuelinj.html
Old Apr 21, 2004 | 09:10 PM
TURBOFTW's Avatar
are the injector clips different i know the for low imped. prelude injectors theres a groove in the middle as on high imped. theres is not ?
Old May 4, 2004 | 08:48 AM
URNVS's Avatar
Default Re: Is there a way to tell if these are low or high impedance injectors? (h22dude)
H22dude - would appreciate if you dropped me a line at linus AT neta DOT com. Thx!
Darrell Bs 10SecEG
Mar 16, 2007 03:21 AM
blusmke
Mar 1, 2007 04:14 PM
integlspwr2k
Oct 24, 2004 01:21 AM
Patron
Mar 9, 2004 03:00 PM
pissedoffsol
May 7, 2003 06:58 AM
