30 whp loss?
Old Apr 21, 2004 | 09:24 AM
slowestcarever's Avatar
Default 30 whp loss?
I went to the dyno a couple of months ago and dynoed my ls/vtec setup at 185whp which i felt was low to begin with. I returned to the dyno yesterday and the car was dynoed at 155 and got lower after every run....the first thing to come to mind was i blew the motor or bent valves so we did a compression test which was 220 across the board, and leakdown was below normal amounts allowed. my tuner is great and knows his stuff in and out, and air fuel was dead on nothing else was touched. what could cause this? we think its electrical(Distributor or msd) but i wanna get some more input before i rip out my msd box...
my mods are:
ls/vtec
type r pistons
ported b16 head
skunk2 stage 2 cams , springs , retainers
type r manifold
3" aem intake
dc jdm 4-1( running open header)
hondata
msd digital 6 and external coil.
everything on the motor has under 3,000 miles on it and the car is not daily driven so any input at all will be greatly appreciated.
Old Apr 21, 2004 | 12:19 PM
up.
Old Apr 21, 2004 | 12:24 PM
G U E C O's Avatar
i think you should be hitting close to 200 or more with that set up
Modified by stock93cx at 3:57 PM 4/22/2004
Old Apr 21, 2004 | 12:59 PM
Default Re: (stock93cx)
thats what i think, but i think maybe my distributor is fuxored or my msd is bad, any input appreciated guys.
Old Apr 21, 2004 | 02:09 PM
1point5CRX's Avatar
Default Re: (slowestcarever)
is there any blow by out the exhaust ?
Old Apr 21, 2004 | 03:40 PM
quick_cx's Avatar
hows the HP curve?...does it go up and stay at one level? or slowly go up?...a friend of mine had a similar problem in his crvtec, it was electronics with him.....good luck....
Old Apr 21, 2004 | 08:20 PM
BlackCivSi's Avatar
Default Re: 30 whp loss? (slowestcarever)
That's a nice little setup you got there for that LS. You should be putting out 200+
Old Apr 21, 2004 | 08:27 PM
Sliced Beard's Avatar
Default Re: 30 whp loss? (PNelsonBLKSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PNelsonBLKSi &raquo;</TD></TR><TR><TD CLASS="quote">That's a nice little setup you got there for that LS. You should be putting out 200+</TD></TR></TABLE>
that is not a 200+ build
that is a ~180 build
your first numbers seemed about right
i dont understand why your power kept dropping tho
i would think the MSD stuff is taking a dump on you
Old Apr 21, 2004 | 11:48 PM
b16vtecsol's Avatar
Default Re: 30 whp loss? (dirtyd463)
maybe the dyno doesn't like you??
Old Apr 22, 2004 | 04:21 AM
Used2beAb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">
i would think the MSD stuff is taking a dump on you</TD></TR></TABLE>
I disagree, Skunk2 stages 2's, ported head, and hondata. With ITR pistons. That maybe not a 200 build. But it should be damn near. Actually theres no reason why that shouldnt go close to 200whp on a dynojet.
Old Apr 22, 2004 | 04:29 AM
Default Re: 30 whp loss? (Used2beAb16)
not really
at most he is running 11.3:1 compression and his cams are not super aggressive
they are more comparable to toda b's
i say that his motor is good for 190 at most
Old Apr 22, 2004 | 06:04 AM
b19coupe's Avatar
Ditch the MSD for a stock ignition and see what happens.
Old Apr 22, 2004 | 07:24 AM
All Motor Rex's Avatar
Default Re: 30 whp loss? (b19coupe)
That should be a 200whp build. I made just over 200whp w/ITR cams and VAFC, so he should get 200 once he gets the bugs worked out.
Like ^ he said, try the stock ignition.
Old Apr 22, 2004 | 10:05 AM
fearless_dsm's Avatar
Default Re: 30 whp loss? (All Motor Rex)
what wheels were you running the first time and what wheels now?We went to the dyno with 13's the first time and hit 230..the 2nd time on gsr wheels we were at 200..wheel size makes a big difference...look at the speed(mph)of both runs.
Old Apr 22, 2004 | 10:15 AM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All Motor Rex &raquo;</TD></TR><TR><TD CLASS="quote">That should be a 200whp build. I made just over 200whp w/ITR cams and VAFC</TD></TR></TABLE>
with stock LS bore? any proof to this claim like a dyno chart or something?
Old Apr 22, 2004 | 12:34 PM
Default Re: 30 whp loss? (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
It was actually on a bone stock ITR block, not an LS. I'm pretty sure I still have the dyno sheet somwhere at home. This was on one of my old motors a few years back.
Old Apr 22, 2004 | 12:48 PM
Default Re: 30 whp loss? (fearless_dsm)
same wheels ,same verything, except i added the 3" intake and removed power steering so i was expecting better#'s not worse....the peak #'s are down by 30 whp and before where vtec used to spike up and rise it now dips about 20 hp and then rises to the lower peak....also the first dyno was smooth and this one is very jagged and peaky if that matters...thanks guys...also where is the cheapest place to get these oem parts online?
Old Apr 22, 2004 | 01:05 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx &raquo;</TD></TR><TR><TD CLASS="quote">you should be hitting close to 200 or more with that set up</TD></TR></TABLE>
BULL CRAP!!!!!!!!!!
all dynos read different....was it the same dyno?
Old Apr 22, 2004 | 06:28 PM
same dyno same everything except i added an intake and removed my power steering...
Old Apr 22, 2004 | 06:54 PM
omega11855's Avatar
check to see what shape your cams are in.
right amount of oil etc do some basics and come back
Old Apr 23, 2004 | 01:37 AM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">that is not a 200+ build
that sounds like a 200HP build to me.
Old Apr 23, 2004 | 03:36 AM
GSRswapandslow.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">not really
i say that his motor is good for 190 at most </TD></TR></TABLE>
so what do you think a 1996 JDM ITR with AN-r header, 3" aem cai, and 2.5" crush bent exhaust would put out??
answer: 191/132.4 at the wheels
Old Apr 23, 2004 | 06:01 AM
i'm gonna pull the digital 6 this weekend...anyone have any idea on how to connect the external coil to the factory ignitor? the black and orange wire from the coil go to the white/blue wire and black/yellowwire form ignitor or is it something else?
Old Apr 30, 2004 | 04:52 PM
frenchy's Avatar
you should be able to get install info and just do the reverse - or search, i just saw an illustrated install thread but i cant remeber where or id link it - keep us posted, ive got msd and it will be intersting to see if that fixes the prob
Old Apr 30, 2004 | 06:43 PM
scatuli's Avatar
Default Re: (frenchy)
you sure your vtec is kicking in? my buddies didnt have enough oil pressure which wouldn't let the lobes switch over. just my two cents
