Auto to Manual Shift question.... post up ur comments
Old Apr 21, 2004 | 08:04 AM
99SlammedCivic's Avatar
Snipper Snapper
Default Auto to Manual Shift question.... post up ur comments
Hey guys , I have a quick question...
I recently did a 5spd to manual swap on my 99 ex.....
I noticed that when shifting into gears , its not very smooth like 5spd cars
^^^ that was with my D series...
We Swaped an LS motor into my civic and I NOTICE THE SAME THING...
Its NOT MY TRANNY.. don't think.. (has less than 30 k on it...)
What can it be...??
Reason I ask is bc I have driven my buddies SI & other friends d series and there cars shift easily....
SOMETIMES IT FEELS LIKE I HAVE TO FORCE IT IN (especially going into second, well kinda all of the gears sometimes..)
Thanks for the help
Old Apr 21, 2004 | 08:05 AM
ABK's Avatar
ABK
Default Re: Auto to Manual Shift question.... post up ur comments (99SlammedCivic)
did you try taking a look at the shitlinkage and the bushings.
Old Apr 21, 2004 | 08:29 AM
Snipper Snapper
I guess I can check that out again...
n e more comments/advice
Old Apr 21, 2004 | 08:32 AM
rxse7n
Guest
Posts: n/a
Both transmissions may just be getting bad (worn synchros).
Old Apr 21, 2004 | 08:33 AM
jolt-tsp's Avatar
Default Re: (99SlammedCivic)
I'd get new poly bushings, and change the fluid. When I went from honda mtf to syncromesh I noticed a big difference. If the tranny had been unused for a while, you might need to give it a few hundred miles for the fluid work its way around also.
Old Apr 21, 2004 | 08:36 AM
Snipper Snapper
The LS Motor/Tranny only has about 28k on it or so.... Real Clean... ..
The bushings.. are they expensive? All fluids have only been in for about 1 month... (Just did the swap in March)
Old Apr 21, 2004 | 08:40 AM
RICE POLICE SIP's Avatar
Not to familiar with EK auto-manual swaps but in the EG the top tranny bracket needs to be changed or get an aftermarket mount made for this swap. Does the engine and everything sit in there the way it should? If it's off then that could cause it to "mess up" good luck bro
Old Apr 21, 2004 | 08:42 AM
Snipper Snapper
yeah... the EK's don't require it...
thanks though
Old Apr 21, 2004 | 08:52 AM
degooser's Avatar
maybe its ur shifter? just throwing out options..
is it stock or what?
ahmad-a
Dec 13, 2006 10:00 AM
Jmumblez2001
Oct 4, 2006 10:02 PM
eboniwoman
May 31, 2005 07:57 AM
Evs-One
Feb 20, 2003 02:05 AM
