Finally got 'em! NSX-R stoppers!!! (56k go away!)
Old Apr 21, 2004 | 04:37 AM
MiraiZ's Avatar
Default Finally got 'em! NSX-R stoppers!!! (56k go away!)
Yup...finally bought them after all these years of wanting them. NSX-R calipers. Now, to get my accord euro R rotors and pads!
sorry for the big pics, no time to resize.
Cleaning them off with my bottle of JDM simple green
Old Apr 21, 2004 | 04:41 AM
Erik95LS's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (MiraiZ)
They look good man. Let us know how you like them to stock after you get them installed.
Old Apr 21, 2004 | 04:43 AM
Philly_NBP_R's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (Erik95LS)
cool!
How are they different from regular NSX calipers? Bigger?
Old Apr 21, 2004 | 04:45 AM
MiraiZ's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (Philly_NBP_R)
the carttrige itself is identical to the regular NSX, the NA2's have a bracket that spaces it out further from the hub to allow bigger rotors....
Old Apr 21, 2004 | 05:09 AM
B18C R Spec's Avatar
Those calipers are SEXY.
Good luck with the outcome.
Don't forget to keep us updated.
Old Apr 21, 2004 | 05:49 AM
TsunamiZC's Avatar
Default Re: (B18C R Spec)
i want NSX brakes too damnit ....
Old Apr 21, 2004 | 08:31 AM
Jon V's Avatar
Default Re: (tsunami_zc)
pics not working
Old Apr 21, 2004 | 09:14 AM
EGgwhite's Avatar
yo the pictures don't work.
Also i too will soon be purchasing some calipers like that, i was just curious what's the price looking like these says? also a curious about the euro rotors....Thanks
Old Apr 21, 2004 | 09:22 AM
Darkteg's Avatar
New User
Default Re: Finally got 'em! NSX-R stoppers!!! (EGgwhite)
pics dont work
Old Apr 21, 2004 | 09:35 AM
Seedc2's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (Darkteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkteg &raquo;</TD></TR><TR><TD CLASS="quote">pics dont work </TD></TR></TABLE>
d|tt0
Old Apr 21, 2004 | 10:22 AM
Kengs's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (kendogg)
Until Mirai's pics start working again...
NA-2/CL-1 calipers (like what he has):
older NA-1 calipers:
Old Apr 21, 2004 | 10:28 AM
TsunamiZC's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">Until Mirai's pics start working again...
:humps monitor:
Old Apr 21, 2004 | 10:46 AM
Jon V's Avatar
what kind of modifications need to be made to fit them on a different car. (integra, civic)
Old Apr 21, 2004 | 10:53 AM
R you serious's Avatar
where did you get them from and of course, how much yen did you spend?
Old Apr 21, 2004 | 01:38 PM
Seedc2's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">what kind of modifications need to be made to fit them on a different car. (integra, civic)</TD></TR></TABLE>
Old Apr 21, 2004 | 01:55 PM
MiraiZ's Avatar
damn ...I hate my webserver!
Old Apr 21, 2004 | 01:57 PM
^jefs0ng's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">damn ...I hate my webserver!</TD></TR></TABLE>
Me too! I'll be glad to host for you.
Old Apr 21, 2004 | 02:16 PM
VarLordahl's Avatar
New User
wow!
Old Apr 21, 2004 | 02:36 PM
jeff652's Avatar
So I'll share.
These caliper brackets are also on the 99-02 3.5 RL. The caliper brackets are the SAME part. The RL uses a single piston caliper, but the 94-95 Legend dual piston caliper BOLTS onto these NSX/RL caliper brackets.
The 99-02 3.5 RL rotor is the one to use for this config.
You have to grind about 2-3mm off the inside of the braket and use the OEM engine mount washers, or use correct size washers (1-2mm think) to get the offset to line up. This is very easy to do. You will also need the longer NSX caliper mount bolts.
This setup is on two of my cars and runs perfect. This will NOT clear a 15" wheel though.
I'm too lazy/busy to take pics, but I will soon.
Jeff
Old Apr 21, 2004 | 04:40 PM
MiraiZ's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (jeff652)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeff652 &raquo;</TD></TR><TR><TD CLASS="quote">So I'll share.
Jeff</TD></TR></TABLE> You can also use Accord Euro R rotors as well. I'm trying to confirm if the Euro R rotors are the same as the TSX rotors.
Old Apr 21, 2004 | 05:03 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeff652 &raquo;</TD></TR><TR><TD CLASS="quote">This setup is on two of my cars and runs perfect. This will NOT clear a 15" wheel though.</TD></TR></TABLE>
What about 16 inch wheels. Spoon SW388's to be exact. I researched and came very close to buying 04 TL brakes for my car, being that they fit with very little modification, however they won't fit under 16's so I am forced to find another big brake solution.
Old Apr 21, 2004 | 05:35 PM
.RJ's Avatar
.RJ
https://honda-tech.com/zerosearch
There were 2 big *** posts about this.
Old Apr 21, 2004 | 06:00 PM
Kengs's Avatar
Default Re: Finally got 'em! NSX-R stoppers!!! (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
What about 16 inch wheels. Spoon SW388's to be exact. I researched and came very close to buying 04 TL brakes for my car, being that they fit with very little modification, however they won't fit under 16's so I am forced to find another big brake solution.</TD></TR></TABLE>
Kendall, according to one of the sellers on Yahoo JPN Auctions, the NA2 calipers will fit on the ITR if you use the JDM 16" wheels...i'll see if i can dig up the pic
Old Apr 21, 2004 | 06:01 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">Kendall, according to one of the sellers on Yahoo JPN Auctions, the NA2 calipers will fit on the ITR if you use the JDM 16" wheels...i'll see if i can dig up the pic</TD></TR></TABLE>
Thanks a million.
Old Apr 21, 2004 | 06:03 PM
Kengs's Avatar
Yes, the NA-2 calipers come in bling gold color too
