Question for those with JDM seats....
Old Oct 30, 2001 | 03:22 PM
JohnnyBoy's Avatar
Default Question for those with JDM seats....
Are the adjusters for incline on the same side for both seats? Also can you switch the adjusters from one side to the other? Thanks in advance.
Old Oct 30, 2001 | 04:26 PM
Dr Pooface's Avatar
Default Re: Question for those with JDM seats.... (JohnnyBoy)
I believe the adjusters are on the inside of each seat (where our center console is) and they cannot be switched from one side to the other. You can however switch the seats to put the adjusters on the outside. I could be wrong, however. I have no first hand experiance on the subject.
[Modified by Dr Pooface, 1:26 AM 10/31/2001]
Old Oct 30, 2001 | 04:49 PM
tracktime's Avatar
Default Re: Question for those with JDM seats.... (Dr Pooface)
recline adjusters should be "facing each other" above your handbrake assembly/center console.
Mounting the recline ***** on the outside facing the door panels will make it harder for you to reach the recline *****.
Best Regards,
Harry
Old Oct 30, 2001 | 04:51 PM
machgo5go's Avatar
I did take off the rails from both JDM recaros and swapped the seat from RHD to lefted hand and same for the other. Now I am sitting on actual driver seat on the LHD with the recline adjuster on both seat facing the doors, instead of the center console, inorder for more ease in reclining. IF u notice now on the new 02 DC5 Rs, the reclining adjuster is facing the door instead toward center console on DC2 Rs.
ed lee
Y2K ITR #498
97 ITR #315 RIP
F22Master
Feb 21, 2013 07:33 PM
imonx850
Jul 26, 2010 01:51 PM
Yellow3TypeR
Nov 23, 2002 01:41 AM
Rdriver
Jun 23, 2002 08:07 AM
machgo5go
Sep 27, 2001 04:58 AM
