Please help car won't start!!
Old Apr 20, 2004 | 08:18 PM
jerm001's Avatar
Default Please help car won't start!!
Ok, my cd deck recently died so I decided to get a new one, took the old one out, and put in the new one, the new one starts up and works perfect, the only problem is now my car won't start, it crancked over for a while, then the battery died, so I hooked it up to my fathers van, to try to jump start it, car would keep crancking, but wouldn't start. Could I have somehow short circuted something while installing the new cd deck?, Or do I need a new battery, I figured that even if my battery was dead, I should be able to start the car with a jumpstart, but I may be wrong, anyway, I really need my car and have no clue as to why it won't start.
Please give me any suggestions,
thanks
Old Apr 20, 2004 | 08:36 PM
Ignitecivic's Avatar
Default Re: Please help car won't start!! (jerm001)
ur battery is prolly in bad condition, check ur starter, and installing a deck wont caused the car to not start.
bring ur battery to a local autozone, kragen etc. to get it check
Old Apr 20, 2004 | 10:10 PM
hatchi's Avatar
did you check your fuses?
Old Apr 21, 2004 | 10:36 AM
jerm001's Avatar
Default Re: Please help car won't start!! (hatchi)
What fuses could be causing this
Old Apr 21, 2004 | 10:38 AM
Kamin's Avatar
Default Re: Please help car won't start!! (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">ur battery is prolly in bad condition, check ur starter, and installing a deck wont caused the car to not start.
bring ur battery to a local autozone, kragen etc. to get it check</TD></TR></TABLE>
sorry if his car is cranking, it has nothing to do with the battery.
you probably blew a fuse, check on the drivers side where your left knee sits. there is a panel there. inspect all of them.
Old Apr 21, 2004 | 12:26 PM
jerm001's Avatar
bump
Old Apr 21, 2004 | 12:31 PM
TRRacer's Avatar
Default Re: (jerm001)
Are you sure you wired it correctly. I put a new CD playin in my hatch and accidentally wired it to the headlights. Now I need to turn them on whenever I want to listen to the radio....make sure you didn't connect it to a constant,
Old Apr 21, 2004 | 12:32 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerm001 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
what are you bumping? have you checked your fuses? ill almost garuntee you popped a fuse for something like the fuel pump relay.
Old Apr 21, 2004 | 12:50 PM
jerm001's Avatar
Checked all fuses, they are all good, I think I'll try getting a new battery and see if that works
Old Apr 21, 2004 | 12:56 PM
jfastman's Avatar
DOOD Check the basics before you go throwin parts at it to find out which ones will stick. YA got spark, fuel pressure?
Old Apr 21, 2004 | 01:52 PM
jerm001's Avatar
yea, sparks, fuel, pressure, everything, and the day before I took it to honda and had them look it over and adjust the timming belt, so everything should be good, it was running great before I went and installed that cd deck
Old Apr 21, 2004 | 02:08 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerm001 &raquo;</TD></TR><TR><TD CLASS="quote">yea, sparks, fuel, pressure, everything, </TD></TR></TABLE>
Is it flooded?
Old Apr 21, 2004 | 02:40 PM
5thgensedan's Avatar
Default Re: (Chiovnidca)
Unhook your CD player and see if it starts. If it does you know that was the problem. If it doesn't rediagnose...
Old Apr 21, 2004 | 04:24 PM
jerm001's Avatar
Default Re: (5thgensedan)
Well I bought a new battery, still doesn't work, SO I'm going to unhook the cd player and see what happens
Old Apr 21, 2004 | 05:09 PM
jerm001's Avatar
Is there some sort of fuse to the fuel pump? should it be making noise when I try to start it? (fuel pump is under rear seats, correct?
Old Apr 21, 2004 | 05:16 PM
DAguyLS's Avatar
yes you should be able to hear it turn on, one click before your car turns over with your key
Old Apr 21, 2004 | 06:31 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerm001 &raquo;</TD></TR><TR><TD CLASS="quote">Is there some sort of fuse to the fuel pump? should it be making noise when I try to start it? (fuel pump is under rear seats, correct?</TD></TR></TABLE>
Didn't you say it had fuel presure?
Old Apr 21, 2004 | 07:55 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Didn't you say it had fuel presure?</TD></TR></TABLE>
exactally. i STILL say you have a blown fuse.
RaysBoomBoomLude
Nov 18, 2009 09:19 PM
lawlss
15
Sep 14, 2009 10:23 PM
reithegreat
Jul 2, 2009 11:20 AM
posterchild
Jun 26, 2004 02:09 PM
