96-00 2DR DX Proportioning VS 4DR
I know I read somewhere that the 2DR DX prop valve is the same as the Si and the CX but I found out that the 4DR DX is different. Does anybody know if the 4DR DX prop valve is 4040 as well for a rear disc conversion?
Oh yeah it's going in a 99 EX in which I believe the master and boost are the same as the Si.
TIA!
TIA!
https://honda-tech.com/zero...age=7
see my post near the bottom of the page. i'm not sure if the prop valves from the dx and si are the same, if i checked that it's in there; but i do know that the brake booster and mc from your 99 ex 2dr is the same as the si - not if you have a 4 door. you can check the part numbers for the prop valves yourself. http://www.slhondaparts.com i believe it's in the brake lines or master power section.
kungpowchicken
Nov 2, 2011 11:13 PM
Propulsion
Mar 20, 2006 07:32 PM
hybrid_racer
49
Jan 14, 2002 04:14 PM
