Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Pilot/Odyssey/MDX owners head up on RECALL
Old Apr 20, 2004 | 08:14 PM
azndng's Avatar
Default Pilot/Odyssey/MDX owners head up on RECALL
i recently seen it on the news
found this article online::::
American Honda to Recall Certain Light Truck Vehicles to Repair Automatic Transmissions
Wednesday April 14, 11:00 am ET
TORRANCE, Calif., April 14 /PRNewswire/ -- American Honda Motor Co., Inc., today announced a voluntary recall of certain Honda and Acura light truck models equipped with V6 engines and five-speed automatic transmissions to inspect and repair a potential defect in the transmission.
The recall involves approximately 600,000 light trucks manufactured in the U.S. and Canada. Affected models include certain model year 2002, 2003 and early 2004 Honda Odyssey minivans; 2003 and early 2004 Honda Pilots; and 2001 and 2002 Acura MDX sport-utility vehicles.
The situation is created by insufficient lubrication of the transmission's secondary shaft second gear that can occur under certain driving conditions. Prolonged operation under these conditions can lead to heat build-up and under certain circumstances may eventually result in chipped or broken gear teeth or breakage of the gear. In the event of a chipped or broken tooth, the owner will likely experience abnormal noise from the transmission and seek repairs. In rare instances, this condition may lead to gear breakage and possible locking of the vehicle's transmission, creating a potential safety hazard.
This more severe condition is extremely rare and affects only vehicles with high mileage. To date, the company's records indicate only ten confirmed instances in the United States and Canada of this type of transmission failure, with no injuries or accidents as a result.
Owners of affected vehicles will be contacted via mail and will be asked to take their vehicle to an authorized Honda or Acura dealer to be repaired free of charge. In most cases, the repair involves a simple gear inspection, which is accomplished without removing or disassembling the transmission, and a modification to increase the flow of transmission fluid to the affected gear. If during the inspection the service technician discovers discoloration of the gear indicating heat damage, Honda will replace the transmission assembly at no cost to the customer. Owners will be notified by mail when parts are available for their model, with notifications going first to the oldest affected units. Customer mailings will begin in May and should be completed by September.
Details regarding mailing dates and affected vehicles will be available on the Honda and Acura Web sites before the end of April. Owners will be able to access this information by registering at the "Owner Link" section of http://www.honda.com or http://www.acura.com and entering the 17-digit vehicle identification number found on the driver's side dashboard near the bottom edge of the windshield.
Customers concerned about the condition of their vehicle may also contact their local Honda or Acura dealer, or call Honda customer service at (800) 999-1009 or Acura customer service at (800) 382-2238.
Old May 3, 2004 | 07:46 AM
Daily Driver's Avatar
Default Re: Pilot/Odyssey/MDX owners head up on RECALL (azndng)
If your vehicle should fall in the production date/vin breaks of this recall you should recieve a postcard informing you of this. You can call your local Honda dealer with the VIN of your vehicle and ask them to find out if you are eligible for any recall.
Please don't just call your dealer with no info and freak out on the person you get on the phone...
<--- works at a dealership...
Old May 11, 2004 | 07:15 AM
jawaite123's Avatar
What would be symptoms of this recall?
We own a 2002 Odyssey and are experiencing some shaking. At first it seemed like a tire out of balance, but now we know it isn't. It shakes (or hesitates) when speed levels off and the gas pedal is released a little -- usually around 1,500 RPM, but not always. It doesn't do it while accelerating or when the gas pedal is released. Any thoughts? I will call the dealer to see about this recall just in case.
Jeremy
Old May 16, 2004 | 01:48 PM
98-tag's Avatar
Default Re: Pilot/Odyssey/MDX owners head up on RECALL (jawaite123)
Good to know I will pass the info on to my Mom.
Old May 18, 2004 | 05:49 PM
Chiovnidca's Avatar
Here's a severe case: https://honda-tech.com/zerothread?id=802829
datkins2
Feb 24, 2019 08:24 AM
Kikkoman23
Jun 4, 2012 10:45 PM
Mr. Projekt
Honda S2000
18
Feb 10, 2007 06:31 PM
SI_you_later
Honda Civic (2006 - 2015)
Feb 5, 2007 05:04 PM
FyrFytr
Aug 6, 2002 01:09 PM
