ITR tranny VS. b16 tranny
what would be a better tranny for my set up
crx with b18c1 motor currently using a ys1 tranny
sucks ***
skunk 2 mani , lightened flywheel, stage 3 clutch, p28 chipped ecu
im looking to run quicker in the 1/4
thanks!
sucks ***skunk 2 mani , lightened flywheel, stage 3 clutch, p28 chipped ecu
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seerxsi »</TD></TR><TR><TD CLASS="quote">is it true that the usdm ITR tranny has a longer final drive a 4.75 i believe?
also how much do the ITR trannys go for??
thanks for the help so far</TD></TR></TABLE>
the JDM ITR tranny has a higher final drive(shorter gearing). Not USDM
ITR trannies go for around 1000-1200. all depends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">
ITR trannies go for around 1000-1200. all depends.</TD></TR></TABLE>
jdm itr 98 spec and up has
4.785 FD
itr 1-3 gears, gsr 4-5
LSD
jdm itr 97 below spec = usdm itr tranny
4.40 fd
1-5 itr gears. (more aggressive 4th gear than jdm itr)
LSD
Si tranny =
same gears as itr usdm
4.40 FD
no LSD
i believe a smaller ring gear than gsr/itr trannies
and possibly a smaller casing?
i'm pretty sure OEM ITR LSDs don't bolt right into Si trannies.
quaife for b16 usually is a great setup for the money.
4.785 FD
LSD
4.40 fd
LSD
Si tranny =
4.40 FD
no LSD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2litreLsVtec »</TD></TR><TR><TD CLASS="quote">here buy this one
https://honda-tech.com/zerothread?id=800210</TD></TR></TABLE>
haha, btw i sent u pm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote">
quaife for b16 usually is a great setup for the money.</TD></TR></TABLE>
Smaller internal diameter ring gear (4.25" vs. 4.5") ... the casings are the same size. An ITR LSD and GSR diff will fit into an Si tranny, but you'll need the larger ring gear.
tomlinson619
25
Dec 14, 2012 11:08 AM
BLKCivicPorscheStyle*
May 5, 2005 06:25 PM
