skunk2stage 1 cams on stock valvetrain?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* »</TD></TR><TR><TD CLASS="quote">your ok....
how can you say he's ok without knowing his redline?
let me be more clear..you're ok up to STOCK redline. take it any further and you're toast...
</TD></TR></TABLE>how can you say he's ok without knowing his redline?
well how do i know what he redlines at?.. the question was, can he run skunk stage 1's on a stock head? and i replied "your ok".. maybe he should of been more specific on his set ups.. i hope that "clears" it up mayn...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* »</TD></TR><TR><TD CLASS="quote">well how do i know what he redlines at?.. the question was, can he run skunk stage 1's on a stock head? and i replied "your ok".. maybe he should of been more specific on his set ups.. i hope that "clears" it up mayn...
I have a set of ITR valve springs, i want to run skunk2 stage 1 cams up to about 8300rpm's, what do you guys recommend as far as upgrading valve springs or retainers. i was thinking about going with portflow inner valve springs, will i be ok with portflow inners and ITR outters on skunk2 stage 1's ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuy02 »</TD></TR><TR><TD CLASS="quote">I have a set of ITR valve springs, i want to run skunk2 stage 1 cams up to about 8300rpm's, what do you guys recommend as far as upgrading valve springs or retainers. i was thinking about going with portflow inner valve springs, will i be ok with portflow inners and ITR outters on skunk2 stage 1's ?</TD></TR></TABLE>
ITR valvesprings work fine w/ skunk2 stage1s since their lift is almost exactly the same as ITRs. These can go safely up to stock ITR redline. I dont recommend using aftermarket titanium retainers b/c of their wear issues...
I think Portflows would be too stiff for S2-S1's since they're not as aggressive. An ITR valvetrain will work just fine up to the ITR redline. I've been told it can handle higher, and I myself have been higher (~9000), but I wouldn't recommend it, and I never did it again myself after that one time.
well it's in an LSVTEC and my head is a b16. i was planning on revving it to 8k, so is it safe to rev it to stock LS redline or B16 redline? i'm guessing b16, but just making sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmfrontin »</TD></TR><TR><TD CLASS="quote">well it's in an LSVTEC and my head is a b16. i was planning on revving it to 8k, so is it safe to rev it to stock LS redline or B16 redline? i'm guessing b16, but just making sure.</TD></TR></TABLE>
Is your block stock? I wouldn't recommend taking it past 8k on a stock LS block. The LS block in stock form has a lower rod ratio than GS-R/ITR blocks, meaning it can't handle high-revs as well.
BukakkEK9
Nov 3, 2006 07:31 PM
weak_sauce
21
Feb 15, 2006 07:53 PM
