AEBS typhoon manifold , FITV hoses ??? ,,,, just installed.
Anyone have pics of this manifold installed on there B16a. I just got finished installing my new manifoild but I need to find out what to do with the coolant lines that went to the FITV since i no longer have a fitv with this AEBS typhoon manifold. I searched and came up with 0 . Can i just run a hose in the shape of a horseshoe from the inlet on the thermostat to the head?> I have everything hooked up except for the one second over from the right of the manifold, ( THE SMALL ONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- »</TD></TR><TR><TD CLASS="quote">is it just me, or does that manifold look real ugly?</TD></TR></TABLE>
I dont think they look to bad once you install it and see it in person but the results and price will make me look the other way.
The only problem is how much clean up work they can use on the inside.
true. So i looped the line that used to go to the FITV from the manifold to the thermostat housing. Seems to be right. Started it up for the first time tonight. First thing I noticed is that my idle went up from its normal 800-900 to 1400. I tightened the idle screw in and only can get it down to 1200 or so. Should I do the hole Helms way , disconnect IACV the adjust , Maybe my TPS is out of wak because I did have the throttle body off to replace gasket. Although i did not remove TPS? I should recheck the timing tomorrow. I checked for vacume leaks, None, new gaskets properly torqued down. ? ??? No longer have a FITV , throttle cable is good tension. Any suggestions?
could you zoom out a little on that pic and could you take a couple pics of how your coolant hoses are hooked up?...looks cool dood,i got a skunk2 mani and my idle is at 1400 also
yah i was affraid of the clearance issue with doing this intake manifold. looks good man.
http://www.ef-honda.com/main/viewtopic.php?t=2463
heres what i found on EF-honda.com awhile back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">Just loop the line.</TD></TR></TABLE>
Yep, I know this is true on my D. You go right back under to the right about 3-5" next to a thicker hose that goes back into the head.
donvito#1
Apr 2, 2007 01:48 PM
Hope you likes!
