15 or 16 inch wheels?
Old Oct 30, 2001 | 02:00 PM
itr501's Avatar
Default 15 or 16 inch wheels?
Ive debating in my mind whether to get 15 or 16's? what are the pros and cons?
Old Oct 30, 2001 | 02:14 PM
Black SVT's Avatar
Default Re: 15 or 16 inch wheels? (itr501)
The only pro I can see to a 16' wheel is it looks a little better.It isn't going to help your acceleration any.Actually it should slow you down a bit.16" tires cost more .On the good side you can put a wider tire under the car which will help you while cornering, etc.However,If you plan on autocrossing I would buy a set of cheap 15' and R compound tires.
Old Oct 30, 2001 | 02:53 PM
Cosworth's Avatar
Default Re: 15 or 16 inch wheels? (MiGs)
16's if you are keeping your stock rims. The only exceptiong is you plan on tracking your car in which 15x7 would help out with larger tires.
Old Oct 30, 2001 | 02:57 PM
Big Phat R's Avatar
Track ==> 15" - R compounds are cheaper in this size
Street ==> 16" - go with forged if you can
BLeSR
Aug 5, 2009 11:51 AM
PatiKTP
Dec 13, 2002 11:45 AM
brasilracing
Sep 13, 2002 12:02 PM
89 CRX SI
Aug 12, 2002 07:58 PM
citanest
May 24, 2002 11:30 PM
