Is my gsr secondary butterflies openning up?
Old Apr 20, 2004 | 05:26 PM
slowsleeper's Avatar
Default Is my gsr secondary butterflies openning up?
Ok, I thought that my car was running fine considering that I was able to run 14.4 in the quarter mile. But untlast weekend, my buddy was in my car with me when i was accelerating and since he previously owned a gsr motor, he was telling me that he wasn't sure if my 2ndary butterflies were openning because it wasn't very loud at high rpms. This isn't the first time that someone has questioned me about the seconday butterflys so thats why i'm not sure as to whether or not they're hooked up. I think that they are because without the short runners, would running 14.4 even be possible? And how can i check to see if it is hooked up??
Old Apr 20, 2004 | 07:51 PM
VtecDeMoN's Avatar
Default Re: Is my gsr secondary butterflies openning up? (slowsleeper)
What ecu are you running?
Brian
Old Apr 21, 2004 | 03:39 AM
tiresmoke's Avatar
what GSR OBD1 or OBD2 ? and what ECU ?
OBD1 w/P72 PInk/blu wire to A17 and Blk wire to ground
OBD2 w/P72 pink/blu to A26 and yel/blk to 12v+ at the yel/blk on the IACV
Old Apr 21, 2004 | 04:12 AM
dash's Avatar
Default Re: Is my gsr secondary butterflies openning up? (tiresmoke)
a way to test them..... look on the drivers side of intake main. and disconnect the electrical connector in the vacuum tank if the arm on the butterflies drops they are working (provided they are hooked up to the right pin out on the ecu)
Old Apr 29, 2004 | 11:09 AM
Default Re: Is my gsr secondary butterflies openning up? (dash)
i'm running a obd1 p72 ecu. and i just rode in a friends gsr and when his secondary butterflies open, its way louder than mine. I'm gonna have to try and check to see if its wired up.
Old Apr 29, 2004 | 12:23 PM
3.3.3's Avatar
hmm....i thought that even if the 2ndaries arent wired up, they will stay open?????
Old Apr 29, 2004 | 01:12 PM
Adam.'s Avatar
Default Re: Is my gsr secondary butterflies openning up? (3 3 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 3 3 &raquo;</TD></TR><TR><TD CLASS="quote">hmm....i thought that even if the 2ndaries arent wired up, they will stay open?????</TD></TR></TABLE>
That was my impression as well. I thought if secondary butterflies weren't wiring they were always on, thus giving better mid range and worse low end torque.
Old Apr 29, 2004 | 02:26 PM
Default Re: Is my gsr secondary butterflies openning up? (DarkKnight[DMD])
when it opens, does the diaphram goes down? If i try to move the secondary butterfly, I have to pull the arm up, so is that shutting the butterfly? Maybe it is open...
Old Apr 30, 2004 | 11:21 AM
3.3.3's Avatar
it should just stay open if you have at least power running to it.
tony7626
Nov 2, 2009 06:36 AM
hondadriver
Jul 10, 2007 10:23 AM
blowme
Jun 29, 2005 04:58 PM
tiresmoke
Apr 22, 2004 05:12 PM
