common motor oil leaks?
Old Apr 20, 2004 | 03:34 PM
magic hat #9's Avatar
Default common motor oil leaks?
i'm currently going through alot of oil; a half quart every 500 miles. this isn't common, even for my oil burner. i'm sure oil is leaking somewhere, but i haven't located it yet. every time i drive for 10+minutes, i can smell burnt oil when i stop - oil on the header.
so, there aren't blue clouds coming out of the tailpipe, there are no oil drops in the garage where i park, the throttle body is sparkling clean, no oil on the spark plugs, there aren't leaks around the valve cover, and the motor compression is great.
my next step is go under the car and clean it with simple green, then look for oil seepage.
where do the c5's most often leak oil? the car has 60k miles and lots of hpde
Old Apr 20, 2004 | 04:29 PM
integrasi's Avatar
Default Re: common motor oil leaks? (magic hat #9)
check if you have enough coolent. u may have crack in the radiator.
Old Apr 20, 2004 | 04:30 PM
BlueR's Avatar
Default Re: common motor oil leaks? (integrasi)
hes looking for OIL!!!
:smacksforehead:
Old Apr 20, 2004 | 04:46 PM
integrasi's Avatar
Default Re: common motor oil leaks? (BlueR)
if your running without coolent, it'll burn off oil crazy
Old Apr 20, 2004 | 04:49 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi &raquo;</TD></TR><TR><TD CLASS="quote">if your running without coolent, it'll burn off oil crazy</TD></TR></TABLE>
if you are running without coolant....that in itself is an oxymoron
Old Apr 20, 2004 | 05:27 PM
cheezthis's Avatar
Well, my GSR (same block) has all kinds of leaks nowadays...
Common ones are as follows...
-cam plug
-cam ring seals
-vtec solenoid
-oil pan gasket
-rear main seal??? ...could be a possible one on mine, not sure yet though.
Check those out, report back.
Old Apr 20, 2004 | 06:03 PM
B2FiNiTY's Avatar
Default Re: common motor oil leaks? (cheezthis)
Dizzy side cam seal, cam gear side oil seals. Valve cover gasket. Those are the most common leak areas.
Old Apr 20, 2004 | 06:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
if you are running without coolant....that in itself is an oxymoron</TD></TR></TABLE>
haha, good one, bluer. the coolant is perfectly fine.
Old Apr 20, 2004 | 06:42 PM
Willard's Avatar
I just replaced the exhaust cam seal on my ~63,000 mile HPDE car.
No big puddles under the car th0.
Old Apr 20, 2004 | 06:46 PM
vtec.dc2's Avatar
also, valve seals, piston rings..
Old Apr 20, 2004 | 06:55 PM
IN VTEC's Avatar
Distributor o-ring - I never thought mine would even leak, but I think it's started.
Less common occurences are the crankcase vapor separator box o-ring and VTEC solenoid gasket/filter.
Old Apr 20, 2004 | 07:04 PM
Warren's Avatar
Wrong-Way Wang
Check your oil pan gasket, rear main seal, and the stupid little PCV box. The boxes crack sometimes.
Also, if you have a remote filter mount, I can almost guarantee that leaks unless you're using the Canton version.
Warren
Old Apr 20, 2004 | 08:26 PM
Default Re: common motor oil leaks? (Warren)
i'm guessing if the oil was leaking from the cam seals (distributor side) i would see oil all around the valve cover and side of motor - none there.
the cam seals on the timing belt side are covered. i did just do a valve adjustment, but i used a new gasket and plenty of hondabond. i don't think this is the leak because the oil must be getting on the header/exhaust to produce the burnt oil smell.
is it difficult to replace the rear main seal? it sounds pricey
i was thinking of putting on a mugen oilpan, this seems like a good time if i want to change the gasket anyway.
Old Apr 20, 2004 | 08:41 PM
irgaszm's Avatar
omg i hope this doesnt happen to mine when i finally find one to buy
Old Apr 20, 2004 | 08:45 PM
RGoose18's Avatar
Default Re: (Non Trbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Non Trbo &raquo;</TD></TR><TR><TD CLASS="quote">omg i hope this doesnt happen to mine when i finally find one to buy</TD></TR></TABLE>
Don't think out loud
Old Apr 20, 2004 | 08:50 PM
Chris's Avatar
My stuation was the same. A quart in 20 min of full throttle high rpm use.
Compression was fine, leakdown was perfect.
OIL RINGS were bad. They werent keeping the cylinder walls clean, oil was blowing out.
My IM was clean and so was the rest of the system (well.. black spots on the bumper) reason it was all clean, is because it was only blowing by at high rpm, when it was hotter and burning off quicker.
Hope this helps, to bad you wont know until you pull it open.
Old Apr 20, 2004 | 09:56 PM
Rdriver's Avatar
Default Re: common motor oil leaks? (Chris)
The dipstick tube is leaking on mine. That seems to be another common one.
Old Apr 21, 2004 | 12:52 AM
00MRSi's Avatar
Default Re: common motor oil leaks? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Dizzy side cam seal, cam gear side oil seals. Valve cover gasket. Those are the most common leak areas. </TD></TR></TABLE>
That's what I was thinking. Also check oil pan, though you'd probably have a puddle of oil if that were the case.
Old Apr 21, 2004 | 03:37 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris &raquo;</TD></TR><TR><TD CLASS="quote">OIL RINGS were bad. They werent keeping the cylinder walls clean, oil was blowing out.</TD></TR></TABLE>
bad how? broke? worn out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris &raquo;</TD></TR><TR><TD CLASS="quote">My IM was clean and so was the rest of the system (well.. black spots on the bumper) reason it was all clean, is because it was only blowing by at high rpm, when it was hotter and burning off quicker.
</TD></TR></TABLE>my back bumper is nasty as fawk right now and that is from ~1200miles of interstate driving.
a little over 1 qt. of oil was burned during that ~1200 miles.
Did you tear down and rebuild with new rings?
Different pistons?
What to do to prevent this/your type of failure next time?
Thanks
Old Apr 21, 2004 | 03:44 AM
.RJ's Avatar
.RJ
Default Re: common motor oil leaks? (Willard)
Time for Will to buy Toda pistons and killer cams
Old Apr 21, 2004 | 03:47 AM
Willard's Avatar
Default Re: common motor oil leaks? (.RJ)
*** that.
some new rings and a nice hone is the best for my wallet.
Old Apr 21, 2004 | 03:49 AM
.RJ's Avatar
.RJ
Hone it with PBR cans
Old Apr 21, 2004 | 05:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris &raquo;</TD></TR><TR><TD CLASS="quote">My stuation was the same. A quart in 20 min of full throttle high rpm use.
could be, but i have no oil on my bumper, plugs, or the inside of my header flange.
Old Apr 21, 2004 | 08:56 AM
typer_801's Avatar
You're probably burning it. Next oil change, look at how clean the oil right after refilling, then wait a few hundred miles (full tank of gas) and then check the color of it again. Cars with failing rings cause the oil to get dark and dirty look very quickly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">
could be, but i have no oil on my bumper, plugs, or the inside of my header flange.</TD></TR></TABLE>
Old Apr 21, 2004 | 01:34 PM
DC2fanboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">every time i drive for 10+minutes, i can smell burnt oil when i stop - oil on the header.</TD></TR></TABLE>
I know this usually isn't common thing... but if there is oil on the header, one place that could possibly drip oil onto the header is from the oil filter... it is conveniently right above the header's 2-1 joint going into the cat. (Always seems to ruin my spotless oil change pan placement )
This wouldn't have started happening after your last oil change, would it? or is it something that has been building up over time?
If you don't get puddles overnight, maybe it is sealed enough that only comes out during circulation? /shrug
