skunk2s?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HonDATACivic »</TD></TR><TR><TD CLASS="quote">skunk2 sucks they reuined my whole motor!
No. . . you ruined your motor, don't blame it on the cams. . . If any cam is properly installed, with proper clearances, and sufficient valve train to support the rpm use and tuned, then any cam will function properly. Skip on any and it so happens to result in a failure, then the responsibility in on you, NOT the cam or manufacturer.
</TD></TR></TABLE>No. . . you ruined your motor, don't blame it on the cams. . . If any cam is properly installed, with proper clearances, and sufficient valve train to support the rpm use and tuned, then any cam will function properly. Skip on any and it so happens to result in a failure, then the responsibility in on you, NOT the cam or manufacturer.
J.nguyen
Aug 20, 2006 08:53 PM
EARLdaSQUIRREL
May 1, 2003 11:24 AM
