Should this have yeilded more?
I know you shouldn't believe everything you read, but...
according to numerous post https://honda-tech.com/zerothread?id=835007 is one I just came across.
Are people legitamitly making 200 whp in gsr blocks with ~11.5:1 cr and higher with toda b's or skunk 2 stage 2 cams?
currently running
gsr block
11.8:1 81.5mm pistons
gsr head milled .010
skunk2 stage 2 cams
adj cam gears set 0, 0
skunk intake manifold
CAI
440cc injectors
T1R header
2.5" exhaust
hondata stage 3 w/p72
my last dyno after final tuning SAE corrected 187whp and 124 tq
A/F was right around 12.5 after 2500 to 8700 rpms
Any suggestions or comments would be greatly appreciated.
Modified by split at 12:59 AM 4/21/2004
currently running
gsr block
skunk2 stage 2 cams
CAI
440cc injectors
T1R header
2.5" exhaust
