Clutch on New Si
Old Apr 20, 2004 | 01:40 PM
t04ecvc's Avatar
Default Clutch on New Si
Anyone changed out their clutch to a Clutchmasters and their flywheel? A friend of mine got the clutch, and they told him he had to use a RSX-S flywheel or the lightened on. He puts it all in and now the clutch won't disengage. Anyone have that problem and if so, how did you fix it? He has a Tech at the local Honda Dealership do the install (he works there also) so I assume it was done correctly, but you never know.
Old Apr 20, 2004 | 01:49 PM
Kal's Avatar
Kal
Default Re: Clutch on New Si (t04ecvc)
did he put a type-s designed clutch/flywheel onto the car? no company makes an aftermarket clutch for k20a3, that's why the flywheel has to be swapped too. is the clutch pedal even going down?
Old Apr 20, 2004 | 02:25 PM
t04ecvc's Avatar
Default Re: Clutch on New Si (Kal)
Yeah, it goes down but it won't disengage.
Old Apr 20, 2004 | 03:11 PM
Kal's Avatar
Kal
maybe the clutch is defective.. try and reinstall it to see what happens.
Old Apr 20, 2004 | 03:38 PM
t04ecvc's Avatar
He had it out and reinstalled, he is going to have the pedal adjusted and see if that helps. It is not fully engaged when the clutch pedal it depressed, but it is catching enough to make the car move when its in gear.
an2ny888
Transmission & Drivetrain
Sep 7, 2010 08:58 PM
lude98SH
Feb 21, 2006 07:28 AM
Chiller
Apr 10, 2005 10:52 PM
