JB Weld a Radiator?
So my radiator has a small hole in it. It is only about 1mm in diameter. Maybe a little larger than a pin hole. I was wondering if rather than replacing the whole damn thing, if I can just dab a little JB weld over the hole? What do you guys think?
I know that the stop leak stuff works...it actually works really well from what I hear, but it is supposed to be shitty for the motor.
"Hell no." ----> I know you can be more insightful than this. Did I miss a thread or something? I have been searching radiators for a while now. I was gonna buy one, but then I thought of the JB weld thing.
JB weld will work well, but it also depends where is the hole. if its at an opening its be easy to do it but if its a corner next any angle leaks can still occured.
I've used JB Weld on an old radiator before. It *sorta* worked. Mine had a crack around the lower pipe (all metal radiator). It stopped the leak enough for me to drive to-from work w/o having to refill the rad every 10 miles. It didn't fix the radiator completely and I just ended up changine out for a new one anyway.
So, I'd say it's a temporary fix. You may also want to go to a boating shop and look for some "underwater" hull repair stuff. It comes in a clear tube and is two-part. You kneed the two together and mold it into place. It hardens up even in water.
Steve
EDIT: the underwater epoxy is called "Aquastick". I've used it to plug a hole in the bottom of a jet ski that was 1" x 0.5" so it should fix a small pinhole.
Steve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Hell no.</TD></TR></TABLE>
follow this advice or you will get stranded one hot hot day with no cell phone and no money and 100 miles from anywhere
guarenteed
guarenteed
Do NOT use that radiator stop leak crap. It has a tendency to clog up heater cores and the narrow radiator passes. Try your luck with the JB weld stuff. Or just spend the few bucks and get a new radiator. That hole is just going to cause bigger headaches down the road. Maybe literally. Having a radiator blow up on you on a road trip = not good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">Do NOT use that radiator stop leak crap. It has a tendency to clog up heater cores and the narrow radiator passes. Try your luck with the JB weld stuff. Or just spend the few bucks and get a new radiator. That hole is just going to cause bigger headaches down the road. Maybe literally. Having a radiator blow up on you on a road trip = not good.</TD></TR></TABLE>
I second that . . . the stuff can cause more problems inside your engine. Fix the radiator on the outside or just replace it. It's not worth the money you'll save . . .
First of all, is your radiator an O.e with plastic end tanks? How do you think JB Weld will hold on plastic if it is?
Secondly where is the hole on the radiator? On a tank? On the core?
Just curious...
I'd never put JB Weld on my radiator.
Just curious...
http://www.radiatorbarn.com
I got a GS-R radiator with aluminum core with plastic end tanks shiiped to my fdoor next day for $120.00.
Lifetime warranty too!
Fit and finish are excellent.
just go to a junkyard and see what you can find...mine had a good size hole in it and i tried all of the above advice but i finally just went to a junkyard and bought a used one for like $25
JDM_ITR
Apr 25, 2002 11:56 AM
Thats why I was asking.
