Crapola, what a day.
Old Apr 20, 2004 | 11:37 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Crapola, what a day.
So I'm reading Secrets of Solo Racing by Henry A. Watts (a great book if you haven't already checked it out), which I've been going through slowly over the past few months, when I get to page 110. The next page is 143. Uh. Yeah. So I guess I'll be ordering another copy.
Afterwards, I get in my car to drive over to the woman's apartment, and my dead pedal breaks off. Luckily, it managed to lodge itself under the brake pedal where it would do the least harm. Accident avoided, I throw it in the back after giving it a few new better-left-unsaid names. It looks like the bolts just ripped out the welded nuts, leaving two nice rectangular holes in the floor. Any ideas?
Lastly, after finally getting to said woman's place, I just happen to look at my front tires, only to see they're pretty much shot because I've been putting off that camber kit. Luckily, I was in the market for new tires anyway, and now know I DO need adjustable camber before I ruin the next set.
Ah yes, and after THAT, one of my rear shocks is squeaking like no other, and while driving doesn't feel bad, I'm now worried that it's blown. So to today.
Edit: To be clear, the mostly-ITR related bit in that is the dead pedal and shock (Zeal B6). Any suggestions on checking/fixing are very much appreciated.
Old Apr 20, 2004 | 12:02 PM
Dr. EKology's Avatar
Default Re: Crapola, what a day. (sscguy)
And nothing happened at the woman's house to maybe make the day better??
Old Apr 20, 2004 | 12:16 PM
Philly_NBP_R's Avatar
Default Re: Crapola, what a day. (EKology)
Had the same stoopid problem with my R. We fixed it with a pair of nuts, bolts, and some big washers. Was a real pain in the *** though... Basically you just need to get a washer big enough to hold the bolt on there - the tough part is getting the nut and washer underneath the metal tab that the oem piece screws into. Heres a tip - pull the carpet back, and take that big plastic cover (knee bolster or something) that is to the left of the clutch pedal out when working on the dead pedal - makes things ALOT easier...
Old Apr 20, 2004 | 12:34 PM
Smitdog's Avatar
Default Re: Crapola, what a day. (Philly_NBP_R)
Thats ashame Adam....... At least nothing major........
Stop By and we can take a look at those Zeals. The weather is like summer....
Old Apr 20, 2004 | 01:16 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">one of my rear shocks is squeaking like no other, and while driving doesn't feel bad, I'm now worried that it's blown.
prolly just your PB mounts making noise , spherical bearings dont like dirt...
take those front tires and toss them on the back , they looked brand new last I saw your car
Old Apr 20, 2004 | 01:26 PM
BlueR's Avatar
Default Re: Crapola, what a day. (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">
good doctor, zeal b/s6 don't have spherical bearings...they come with hard rubber bushings
the only Zeal setup the comes with spherical bearings is the Super Function line
Old Apr 20, 2004 | 01:31 PM
Chris's Avatar
Default Re: Crapola, what a day. (BlueR)
camber DOES NOT cause excessive tire wear.
The lowering causes more negative camber yes, but it ALSO causes toe IN which wears out the inside of the tire.
Leave the camber alone, and adjust the toe back to spec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
oopsie , I just figured his did , the have all the other bling features
hard bushings = squeakie also.
Old Apr 20, 2004 | 01:32 PM
BlueR's Avatar
lol...lets just hope thats it :fingerscrossed:
Old Apr 20, 2004 | 02:25 PM
Suspetise...
Thanks all for the help. Philly, I'll try that, hopefully that'll work. For the tires, Jamie, it's way worse than when I was last at your place. You know that rain groove on the inside of the Falkens? Well, it isn't there any more on the passenger side. Chris, I understand that a bad alignment would cause tire wear quicker than camber, but my alignment is good. Maybe I need ANOTHER one...
I thought of the polyurethane (is that the rubber in the B6s?) and how that squeaks, but why would it only be on one corner?
As for the woman...that'll be taken care of later tonight. I only had 5 minutes there, and that's just not enough time .
Old Apr 20, 2004 | 02:44 PM
Tweakmeister's Avatar
yay for maryland
Old Apr 20, 2004 | 02:50 PM
Kendall's Avatar
All of a sudden I'm glad that I have long since removed the dead pedal in the name of weight reduction.
Old Apr 20, 2004 | 02:51 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Crapola, what a day. (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">yay for maryland</TD></TR></TABLE>
Ghetto
Old Apr 20, 2004 | 05:49 PM
Default Re: (Kendall)
glad I could help... I was waiting for someone else to have this problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">All of a sudden I'm glad that I have long since removed the dead pedal in the name of weight reduction.</TD></TR></TABLE>
mine tried to remove itself, but I was like
GET BACK IN THERE AND DO YOUR JOB BEEYYOTCH!!!
lol
(actually Eluder200K helped me fix the damn thing - friggin crappy japanese buckets )
Old Apr 20, 2004 | 09:42 PM
Bigpimp_murf's Avatar
As for the woman...that'll be taken care of later tonight. I only had 5 minutes there, and that's just not enough time .</TD></TR></TABLE>
**Slumps down in chair thinkin 5 mins. is 3 mins. too long**
Old Apr 20, 2004 | 09:47 PM
DsITR's Avatar
IIRC the squeeking issue w/the Zeals is a normal thing.
I remember Trey talking about it awhile back.
Tires will be taken care of shortly
Old Apr 21, 2004 | 06:27 AM
mstewar's Avatar
i've been saying that a lot lately..
sorry to hear about the annoyances man.. at least nothing major happened..
Old Apr 21, 2004 | 07:15 PM
Default Re: Crapola, what a day. (Ross R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R &raquo;</TD></TR><TR><TD CLASS="quote">
Ghetto </TD></TR></TABLE>
what's even more funny is this is coming from the guy in DC
Old Apr 21, 2004 | 07:16 PM
Default Re: Crapola, what a day. (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
so true...
Fo-Do Fanatic
Jan 2, 2010 04:26 AM
mekal
Aug 25, 2009 11:40 AM
lilpastrana
Mar 9, 2007 06:07 PM
hatch_
Oct 23, 2006 04:07 PM
Tuesdaynightfever
31
May 24, 2006 06:03 AM
