No Vtec
the dizzy went out on my gsr a couple weeks ago i got a new one last night and now my car doesnt hit vtec anymore. i know the dizzy isnt the problem but i cant figure it out ive got good oil pressure and my car has always hit vtec ever since i did the swap last october now for some strange reason nothing. whats the best way to diagnose
I think the obvious thing to do would be to double and triple check that you installed the dizzy correctly? Was vtec engaging before you switched out the dizzy? Do you have any CEL'S?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-Civic »</TD></TR><TR><TD CLASS="quote">WHats a "dizzy" ?</TD></TR></TABLE>
Distributor.
Distributor.
also i pulled my stock intake off and there is oil in my throttle body and intake tube. what would of caused this. is there a seal i could have blown or something. maybe causing my to have low oil pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">you prolly ripped out some vtec wires</TD></TR></TABLE>
That's what I'm thinking too. I'm willing to bet the code is vtec solenoid. Having those codes would really help
since today is 4/20 and you obviously like to roll blunts you shouldn't attemp fixing your vtec today. Double check the vtec oil pressure, and selonoid wires It's really easy to rip them.
i finally got it to flash codes its throwing
21 VTEC spool solenoid valve
22 VTEC pressure valve
And when the car is running and i check the codes it throws
8 i belive its top dead center sensor
Modified by 92B20GSR at 9:01 PM 4/20/2004
Did you time the ingnition after replacing the Dizzy? Check the connections on the dizzy too. I think that top dead sensor has something to do with engaging of vtec but I'm not sure. Also the vtec oil pressure sensor is right by the selonoid with two wires coming out of one goes to the ground second goes to the ECU.
Also read this:
https://honda-tech.com/zerothread?id=586847
https://honda-tech.com/zerothread?id=85791
Also read this:
http://www.slhondaparts.com/im...5.jpg
People say it's part #4 so you will basicly have to take your old distributor housing (part #4) and swap all the parts to it from the new one. I guess the sensor is in the housing. Did you try doing ignitions timing?
