210hp
Old Apr 20, 2004 | 10:37 AM
heroinbobaa's Avatar
Default 210hp
i want to get my integra to 210hp if i put a exhaust header intake manifold pulleys cat intake cams and cam gears will the hp be around 210. if not what does anyone sugest to do to get it to that.
Old Apr 20, 2004 | 10:46 AM
SawBoss's Avatar
Default Re: 210hp (heroinbobaa)
are you talkin 210 at the wheels? i think your combo will fall short of that target. check out some dyno sheets at importreview.com and view some of their set-ups. good luck
Old Apr 20, 2004 | 02:35 PM
Big Phat R's Avatar
High-lift long-duration cams (Toda B/C, Jun III etc) with high compression 11.5:1+ and valvetrain.
Hytech or SMSP header
2.5" exhaust
310 cc/min or larger injectors
fuel-pressure riser/controller
fully tuned ECU (Hondata or AEM) and lots of dyno time
Old Apr 20, 2004 | 02:37 PM
TOP*SECRET's Avatar
MORE POWER!!
Old Apr 20, 2004 | 03:22 PM
TeamSTEALTH GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heroinbobaa &raquo;</TD></TR><TR><TD CLASS="quote">i want to get my integra to 210hp if i put a exhaust header intake manifold pulleys cat intake cams and cam gears will the hp be around 210. if not what does anyone sugest to do to get it to that.</TD></TR></TABLE>
what kinda integra/motor?
Old Apr 20, 2004 | 05:09 PM
obd2gsr's Avatar
More info needed... What kinda cams, what kind of exhaust, what kind of header, what kind of engine is this going in, what kind of ... everything... u get the picture.
Old Apr 21, 2004 | 08:27 PM
BlackCivSi's Avatar
It sounds like you need to do some more researching. Find out exactly what you want for each application of your engine. To get 210HP at the wheels will cost you some $$$ depending on what engine you have. What B-Series is it?
Old Apr 21, 2004 | 08:31 PM
Sliced Beard's Avatar
Default Re: 210hp (PNelsonBLKSi)
you will need much much more than those simple bolt ons no matter what engine you have
Old Apr 22, 2004 | 04:31 AM
Used2beAb16's Avatar
Default Re: 210hp (dirtyd463)
unless it was a k20a. (its not)
dbiker207
27
Apr 6, 2007 12:49 PM
gsrboost
Jul 31, 2006 11:53 AM
heroinbobaa
Apr 20, 2004 10:38 AM
2nrDren320
Jan 4, 2004 08:31 PM
r1dreams
Jul 28, 2003 07:47 PM
