s20 Tranny install and prep.
Old Apr 20, 2004 | 09:35 AM
drewbie*'s Avatar
Default s20 Tranny install and prep.
I am getting ready to replace my junk cx tranny with a s20 tranny that i picked up over the weekend, Thanks to Mamaboy .
Anyways I'm doing a mini me on my d15b8 which i will take pictures and document for my hatch restoration project. I am also doing general maintenance since the motor has around 100k. For the tranny I would like to know what is the best way to prep for a fresh install. I have a new exedy clutch in the cx tranny which i will be using. So far I'm going to replace all the seals and get the flywheel resurfaced. What else should I do to get this thing ready to go? It's been sitting for a while and could use a good clean up, what would you recommend to get it nice and clean.?
Thanks.
For the actual install I will be pulling the whole motor out. I picked up a 2 ton engine hoist for $100 since I don't have a lot of room to work. Thanks.
Old Apr 20, 2004 | 09:42 AM
BauleyCivic's Avatar
Risky Business
Default Re: s20 Tranny install and prep. (Drew95eg)
Spray the entire transmission with brake cleaner. Get the FW resurfaced. You will need these parts:
-Both Axle Seals in Transmission
-Input shaft bearing in transmission
-Input shaft seal in transmission
-Rear main seal in block
I didn't replace the rear main or the input shaft seal when I did my tranny/clutch. Now, one of them is leaking and my brand new clutch is ruined.
Old Apr 20, 2004 | 09:56 AM
drewbie*'s Avatar
Default Re: s20 Tranny install and prep. (BauleyCivic)
big ups to you sir. always there to help mini me projects out.
I owe you some beer lol.
Tealeg88
Nov 30, 2005 12:08 PM
solk1dd
Aug 3, 2005 02:21 AM
AnNiMosSiTY
Oct 27, 2004 06:28 PM
integraGSR213
Feb 9, 2004 03:16 PM
R-gonaut
May 24, 2003 05:43 AM
