Where to buy oversized intake valves for B18B?
Old Apr 20, 2004 | 09:02 AM
Thrillhouse's Avatar
Default Where to buy oversized intake valves for B18B?
I know this should be posted in the classifieds but it will never be seen that **** moves so fast, and plus this is an all motor question.
I want to make my B18B head breathe better and am wondering where I can buy these. I only need the intake side, the exhaust side will stay the stock.
Old Apr 20, 2004 | 09:43 AM
:thumbsdown:
Guest
Posts: n/a
Default Re: Where to buy oversized intake valves for B18B? (Thrillhouse)
why oversize? on most application it has no gains.
and you can't run big cams with them.
therefore, useless
Old Apr 20, 2004 | 03:06 PM
JCushing's Avatar
you can get .5mm over sized ss valves from crower...
oh and if there not worth while then why would vtec heads come with 33mm intake valves?
IMHO one of the reasons that non vtec motors make mean midrange they do is the valve sizing compared to vtec heads. granted they wont flow near as much 8k+ but who cares.. over 8500 non vtec heads basically fall apart anyway soo...
Old Apr 20, 2004 | 03:09 PM
badCRX's Avatar
New User
Default Re: Where to buy oversized intake valves for B18B? (JCushing)
Check with Stan at http://www.fast-turbo.com
Old Apr 20, 2004 | 07:14 PM
Default Re: Where to buy oversized intake valves for B18B? (badCRX)
So you guys think that larger valves would kill the midrange on an LS? I thought the LS had such a mid range because of the longer stroke? Anyways some good info so far, any other places that sell flat faced valves?
Old Apr 20, 2004 | 07:47 PM
MadnessRacing's Avatar
just call tom at 818 335 5316 thats camp1320 hell get what you need
Old Apr 21, 2004 | 02:23 AM
JCushing's Avatar
im talking about basically the same motor before and after vtec. also dont forget that a vtec engine is on the small cam intill 6k with aftermarket camsso before that our 1 lobe is gonna be ALOT bigger.
Old Apr 21, 2004 | 07:40 AM
Rob Dizzle's Avatar
you dont need oversize
just get normal sized and you will be fine
heres a lil tech article on valves
here=
Old Apr 23, 2004 | 11:09 AM
fordorshocker's Avatar
Go with the crower valves
FMN716
23
Oct 31, 2010 07:05 PM
90datech
Jan 23, 2007 09:52 AM
CivicDude2k4
May 25, 2006 12:10 PM
b20integrapower
Jan 29, 2006 10:41 PM
K-Drum
Sep 27, 2004 10:35 AM
