Clutch pedal pressure variations while driving
I noticed that sometimes the pressure of my clutch pedal will change.
For example, when I rev the motor to a high enough RPM (in or out of gear), the pedal will feel significantly softer than normal.
Anyone experience this? My hydraulic system should be OK...I changed the slave not long ago. Maybe fluid level?
I have the same mileage as the dude above.
I checked the fluid level, and all is OK. But why does the pedal feel softer at higher RPMs? Is something working harder?
DeViuS
Feb 17, 2021 11:33 AM
benzo_tek
Nov 13, 2007 05:38 AM
