ecu trouble code?!?!
Old Apr 19, 2004 | 09:23 PM
hondaZvic's Avatar
Default ecu trouble code?!?!
i have an 88 dx. completely stock..
when i reset the ecu and check it.. the led on the ecu flashes one time real quick and stays off...
then after driving it for a while the check engine light will come on. so i check the ecu.. and the led light just does a continious flash. i counted it up to 30+ and then i got tired....
any thoughts/ help?
tia
Z
Old Apr 20, 2004 | 09:01 AM
EF9Dreams's Avatar
Default Re: ecu trouble code?!?! (hondaZvic)
count how many times it blinks and check the codes on honda-tech... go to seach and type in ECU codes...
Old Apr 20, 2004 | 11:05 AM
hondaZvic's Avatar
Default Re: ecu trouble code?!?! (EF9Dreams)
thats what im saying.. it just keeps blinking... and they are in no pattern.. just a continous blink...
there would be about 3 seconds in between each blink.
i counted up to 30 blinks.. then i quit...
Old Apr 20, 2004 | 05:19 PM
EF9Dreams's Avatar
theres 90 different codes so if it straight up blinks then just keep counting them
Old Apr 21, 2004 | 06:17 PM
hondaZvic's Avatar
90 ?.. i thought there was only 20 for obd 0?...
Old Apr 21, 2004 | 06:26 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
code 1
Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
If the CEL goes on after driving for a while it is in fact an old O2 sensor.
get a cheap Bosch replacement from autoparts store and reset your ECM.
stan
awalp
Nov 15, 2006 08:25 AM
EFin' Kyle
Sep 29, 2004 07:47 PM
kimo98GSR
Jun 30, 2004 09:51 PM
stockintegra
Mar 27, 2004 02:13 PM
Charlie Moua
Jan 13, 2003 08:32 AM
