RSX seats.......comments
Old Apr 19, 2004 | 07:52 PM
730_Si's Avatar
Default RSX seats.......comments
just wonderin if it is easy to install rsx seats in a 93 honda civic hatch. is it a exact fit?? thanx for ne input.
Old Apr 19, 2004 | 08:38 PM
North_Texas's Avatar
Default Re: RSX seats.......comments (730_Si)
You probably have to switch the rail from the EG onto the RSX seats, I believe.
Old Apr 19, 2004 | 08:40 PM
Ejay Six's Avatar
Default Re: RSX seats.......comments (iluvGiRls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvGiRls &raquo;</TD></TR><TR><TD CLASS="quote">You probably have to switch the rail from the EG onto the RSX seats, I believe.</TD></TR></TABLE>
I believe that wont work. You will have to cut the stock feet off the RSX rails and bolt on new L-Brackets to mount to your EG's floor. Good luck, RSX seats kick ***.
Old Apr 19, 2004 | 09:03 PM
Default Re: RSX seats.......comments (Ejay Six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ejay Six &raquo;</TD></TR><TR><TD CLASS="quote">
I believe that wont work. You will have to cut the stock feet off the RSX rails and bolt on new L-Brackets to mount to your EG's floor. Good luck, RSX seats kick ***.</TD></TR></TABLE>
Oh sorry, well just posted something I thought would help. Oh well.
Old Apr 28, 2004 | 09:17 AM
snatch13's Avatar
anyone have any pics of rsx seats in their civic? id like to see some because im considering doing it myself
Old Apr 28, 2004 | 10:14 AM
TurboBumblBee's Avatar
Default Re: RSX seats.......comments (snatch13)
tooo much fab work to make then fit well.. been through it and drove the car w/ rsx seats.. they sit really high so you need to be able to fab somehting up to lower them alot.. also they are HEAVY!! and you need the seat belt clips from your stock seats on the rsx seats or you will not have seat belts...
*edit
you also cant swap the rails out from an rsx to an civic like you can w/ integra and civic seats.. totally differernt railing and design...
Trurazaflo
Welding / Fabrication
Jun 6, 2013 06:16 AM
EvenStar
Oct 24, 2006 09:47 PM
Groove_D
Aug 16, 2006 02:44 PM
hookedonvtec
Apr 28, 2004 11:29 PM
egjoe
15
Aug 28, 2003 07:52 AM
