Tail Lights arent working
Old Apr 19, 2004 | 07:30 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Tail Lights arent working
my tail lights arent working but my parking lights work so its not the bulbs. i lost the cover to where the fuses are so i was wondering if anyone has a copy of what the cover looks like or if anyone could help me out to find the correct fuse. i have a 99 civic dx btw..thanks in advance
Old Apr 19, 2004 | 07:44 PM
HyBriDcxR's Avatar
Default Re: Tail Lights arent working (ciRcuitSi y0!)
I had this problem.
Honk your horn. If it doesn't make a sound go under your hood and change the fuse. That's if it's still under your hood.
The brake light and horn share the same fuse.
Old Apr 19, 2004 | 09:01 PM
jus f0 dekarayshunZ
Default Re: Tail Lights arent working (HyBriDcxR)
well if thats true..my horn hasnt been working for a long time but my brake lights have been working
Old Apr 19, 2004 | 10:02 PM
awdlaunch132's Avatar
it could be a bad ground on your cd player. if your brake lights don't work and your gauges go dim from everyonce in a while its def that.
Old Apr 19, 2004 | 10:13 PM
hatchy92's Avatar
please check your bulb, its quite easy and if that is the problem, you will be kicking yourself in the *** for not spending a couple of dollars!
Old Apr 19, 2004 | 10:15 PM
Ejay Six's Avatar
Default Re: (hatchy92)
**** y0 taillights
Old Apr 19, 2004 | 10:24 PM
eg_nezay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuitSi y0! &raquo;</TD></TR><TR><TD CLASS="quote">my tail lights arent working but my parking lights work so its not the bulbs. </TD></TR></TABLE>
You sure? There is actually 2 signals coming out of the bulb did you know?
1) For your parking lights.
2) When you press your brakes.
So, #2 can be burned.
Buy a new light bulb j0t0
Old Apr 20, 2004 | 01:50 PM
shorty91's Avatar
Default Re: Tail Lights arent working (eg_nezay)
last week my dad said my brake lights didnt work, so i checked all the bulbs and they worked fine. we checked out all the fuses and they were fine too. but the dual filiment bulb burned out on both brake lights. the running lights worked but the brake lights were out.
somehow all three of my braking lights burned out
so try new bulbs first
Old Apr 20, 2004 | 03:31 PM
jus f0 dekarayshunZ
Default Re: Tail Lights arent working (shorty91)
it was the fuse thanks
Old Apr 20, 2004 | 06:27 PM
eg_nezay's Avatar
EDIT- Ill be nice
blkbond8065
Aug 27, 2015 02:34 PM
lilshady6796
Nov 12, 2008 06:33 PM
ShawnS4363
Sep 2, 2008 01:23 AM
goshred025
Feb 13, 2005 04:35 PM
NiceDc2r
May 13, 2004 09:42 PM
